Any one running 245/40's on 18x8 rims??
Old Nov 29, 2002 | 03:25 PM
TheOzzfather's Avatar
If so are you getting any rubbing or any adverse affects from that size? Thxs in advance!
Old Nov 29, 2002 | 05:34 PM
chinaonnitrous1's Avatar
Re: Any one running 245/40's on 18x8 rims??
I dont think thats reccomended, when i purchased my tires theyre 245/40/18..my wheels are 18x8.5" I think it would be a tad wide to fit properly.
Old Nov 29, 2002 | 05:38 PM
UMD_MaxSE's Avatar
Got Bent?
It all depends on the offset of the wheel and how much you are lowered (if at all). At stock height I don't think you will have any problems as long as the wheel has an offset of 35...
Old Nov 29, 2002 | 08:01 PM
y2kse's Avatar
Re: Re: Any one running 245/40's on 18x8 rims??
The nice thing about acceptable rim width ranges is that thinking isn't required. It's simply a matter of looking up the rim width ranges for your tire size in the Tire & Rim Width Association Contour (Rim Width) Charts. Those charts are available on Page 5 of the FAQs. And yes, a 245/40 tire will fit properly on an 8.0"-wide rim. Whether the tire rubs, however, is another matter entirely.
Old Nov 29, 2002 | 08:39 PM
maximadave's Avatar
detailerdaveb@gmail.com
I recommend it! 235/40's to me has too much wheel gap with Maxspeeds IMO...245/40 is safe on a 18x8 rim---no rubbing
Old Nov 29, 2002 | 08:42 PM
SterlingMist00's Avatar
Running 245/40 S-03s on 18x8 (+38mm offset) SSR GT1s- No rubbing with stock suspension height.
Old Nov 30, 2002 | 05:04 AM
Noob question then...
How do I tell my offset?
Old Nov 30, 2002 | 06:36 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Noob question then...
what kind of wheel is it? We can look up the specs....
Old Nov 30, 2002 | 07:12 AM
Just the factory whells taht came witht he car....
If you are refering to the new rims they are the Moda 6. Feel free to e-mail me at work if you like. Ryan.osborn@fleet.gecapital.com
Thanks so much!
Old Nov 30, 2002 | 08:36 AM
Stereodude's Avatar
I have 245/40 on 35mm offset rims. No rubbing here.
Stereodude
Old Nov 30, 2002 | 12:52 PM
irvine78's Avatar
Malik has 245/40s on 18x8 rims. they're fine! how do i know? those rims are now on my car! muhahahaha
Old Nov 30, 2002 | 03:35 PM
UMD_MaxSE's Avatar
Got Bent?
Re: Just the factory whells taht came witht he car....
Thanks so much!
I think Moda R6 come in both 45 offset and 38 offset. They weigh 27 lbs tho
Stock wheels are 45 offset.
Old Nov 30, 2002 | 06:29 PM
emax02's Avatar
245's fit fine, I think with a +35 mm off set 255 would even be safe.
245's fit rims from 8.0-9.0 inches, 8.5 is "recomended".
Old Dec 1, 2002 | 11:50 AM
But how do I find out my offset...
No one has answered that yet. Thank you. I might not reply for a week I leave shortly for San Diego. Later and thxs!
Old Dec 1, 2002 | 09:25 PM
Stereodude's Avatar
Yes, but 8.5" wide and 35mm offset = rubbing. I think you need at least 38mm with an 8.5" wide rim. So, you can't put a 255 with a 35mm offest because you'd need at least 8.5" to use a 255.
Stereodude
Old Dec 1, 2002 | 11:37 PM
mykmar10's Avatar
Im running that size
I have 245/40-18's on SSR GT1 18x8 inch wheels and not a problem.
Old Dec 2, 2002 | 11:32 PM
emax02's Avatar
Stereodude
I have more then enough room to run another 10mm's on my car. Remember the lower the offset # the further the tires stick out. The further out the tires are the less chance of rubbing. Am I wrong? That seems to be logical to me. Some time next year I plan on getting 17X9 inch rims with 265 series tires
Old Dec 3, 2002 | 12:17 AM
irvine78's Avatar
well, less chance of rubbing the inner liner of your car but if your car is really sitting low, that also means that you're going to beat the crap out of your outter fenders...
Old Dec 3, 2002 | 12:19 PM
Tripower's Avatar
Which offset then???
So, which offset would work best on an 18x8 Moda R6 running 245/40 tires? I'm thinking about the same set up.
Those rims couldn't be much heavier than the stockers.
Old Dec 4, 2002 | 12:09 PM
Tripower's Avatar
No answers?
Old Dec 4, 2002 | 12:41 PM
T-bone's Avatar
I also have this tire size. One big differnce is that they follow the irregularities in the road more than the 225's. I have had no problems with rubbing.
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
