2002 Hid's conversion problems
Old Dec 6, 2002 | 10:18 AM
LatinMax's Avatar
I have a 2000 Nissan Maxima and did the 2002 conversion that Alex provided me and it works great. I also did the side marker rewire in front and back. But I have one problem, sometimes when I put the turn signals on it will flash the HID's (it is a very fast, split second turn off and then back on) I almost did not no what it was at first. It also happens when they turn back of automaticlly. It does not happen all the time but at least every 3-4 times I turn.
Anyone else haveing the same problem or better yey anyone that HAS had it and HAS fixed it.
Help me,
Gabriel
Old Dec 6, 2002 | 10:30 AM
kramerica72's Avatar
Re: 2002 Hid's conversion problems
Help me,
Gabriel
Sounds like you have a bad/loose connection with the high beam/low beam switch or headlight switch on the column, as this is about the only thing that would make them blink. You may need to replace the stalk as I don't think it is a repairable part.
Old Dec 6, 2002 | 11:03 AM
LatinMax's Avatar
Re: Re: 2002 Hid's conversion problems
Thanks for the info. I will look into that.
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
Hdnseek
Sep 9, 2015 05:55 AM
