2K-2K1 5spds with 2K2/2K3 Shifter Console Swap?
Old Dec 11, 2002 | 03:04 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Is yours creaking like a SOB now that it's "cold"?
Mine is!
Plus, my SMC STS hits underneath the boot on 1/3/5 gear. Now, I have to "adjust" it(read uninstall/reinstall) so it's not soooo low.
Just complaining.
Old Dec 11, 2002 | 03:10 PM
Colonel's Avatar
Old Fuddy Duddy
Re: 2K-2K1 5spds with 2K2/2K3 Shifter Console Swap?
Mine is!
Just complaining.
Nope...no issues what so ever!
I dont have a STS...saving for my "happiness"!
Old Dec 11, 2002 | 03:57 PM
IceY2K1's Avatar
Re: Re: 2K-2K1 5spds with 2K2/2K3 Shifter Console Swap?
Old Dec 11, 2002 | 05:08 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
No problems here!
Old Dec 12, 2002 | 08:34 AM
T-bone's Avatar
I have my sts set on 75%. Is this going to be a problem if I swap out for the 2k2 console?
Old Dec 12, 2002 | 08:44 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: 2K-2K1 5spds with 2K2/2K3 Shifter Console Swap?
Phssst....phsssst.
Old Dec 12, 2002 | 08:51 AM
max34's Avatar
Mine is!
Just complaining.
Let me know how it goes. I was planning on getting the console.
I've got the STS shifter.
Old Dec 12, 2002 | 08:58 AM
IceY2K1's Avatar
Re: Re: Re: Re: 2K-2K1 5spds with 2K2/2K3 Shifter Console Swap?
Phssst....phsssst.
Old Dec 12, 2002 | 09:14 AM
IceY2K1's Avatar
I'm not sure what 75% means.
I have the top edge of the ball covering the top thread. You could in theory go half the ***** diameter(radius) more and put the hex screw right on the top most thread, so I'd consider that 100%.
I have mine pretty much as low as you can go and it works with the 2K2 console. It just bothers me that it hits, but the only reason I noticed it was because I would get a vibration/rattling sound in 3rd/5th when I would accelerate. The drivetrain vibration was rattling through the shifter to the console. I also suspect that might be the reason why I have to force it into gear quite often.
I plan on "adjusting"(read UNINSTALLING and reinstalling) my SMC STS over the holidays, so I should know more later.
Old Dec 12, 2002 | 11:24 AM
MichaelAE's Avatar
No creaking here...did you maybe break one of the clips?
Old Dec 12, 2002 | 11:29 AM
T-bone's Avatar
75% means that the shifter is set 75% of the lowest setting (aka 100%..what you have). I don't think I will have problems if I swap the consoles
Old Dec 12, 2002 | 11:31 AM
maxman00's Avatar
To avoid this problem I bent my pacesetter slightly, however that was a big mistake, because I bent it too much. Now I have to take the darn thing out and try to bend it back a little. I may just buy a new sts. I am thinking maybe the stillen, or the b&m.
Old Dec 12, 2002 | 11:41 AM
MOBOY's Avatar
I have had no problems with my STS. I set it so about 1/4 " of the treads are showing.
My gripe about the consol is that I must pull up on the emergency brake lever too high, and the rubber piece that surrounds the lever is just dangling. It also gets hung up and I have the stick my thumb in there to release the brake. Kind of sux!
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
atriuum
Sep 28, 2015 01:19 PM
