Clear Corners are FOGGING UP :(
Re: Clear Corners are FOGGING UP :(
Originally posted by Igor911
Hey guys,
My clears are fogging up since we have cold weather now in MD.
What can i do to stop them from fogging?
I have a 2k max
Hey guys,
I have a 2k max
Re: Re: Clear Corners are FOGGING UP :(
Originally posted by sloppymax
pull them out and put a coating of clear silicone on the crease of the light. this will keep out moisture almost completely. if youve already done that then there isnt too much left except make sure you are using a regular bulb and not led and the heat might burn off some of the condensation.
You have to make sure that you've chased all the water and water vapor out. Otherwise all you've done is seal it up inside. FWIW, using a hair dryer to heat everything from the inside works quite nicely. Aim it through the bulb hole, but make sure to leave space for the air (and the moisture!) to get out. After the light assembly has been warm to the touch everywhere for a couple of minutes or so you should be done. I had this problem exactly once with the driver's side headlight on my Mazda 626.
Norm
Norm
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
