Third Brake Light Idiot light
I have an '02 Maxima GLE. After I bought it I had a spoiler installed. They tapped the wires in the trunk to get the brake light on the spoiler to work. I want to remove the OEM third brake light in the rear window. The dealer sells a color matched part to cover the hole in the rear deck lid. My problem is every time I disconnect the OEM rear window brake light the idiot light on the dash comes on when the brakes are applied telling me I have a light bulb out. Is there a jumper wire or something available that would allow me to remove this light and have the car think all is well? Any help would be greatly appreciated. I attempted to wire the spoiler light back to the harness for the OEM light but the car wasn't fooled for a moment. The idiot light came on. Thanks.
Something is definitely wired wrong. When I installed my spoiler with LED brake lights, I wired into the center brake light wire harness and removed the bulb. No problems with any idiot lights coming on for me. Check to make sure nothing got disconnected when you played with the wires. Also, LED lights need to be wired with the correct polarity, unlike a regular bulb.
Re: Third Brake Light Idiot light
Re: Re: Third Brake Light Idiot light
If any of the above posters (or anyone else) is interested in selling the third brake light, I might be interested.
Please email me directly to discuss. Not sure if this matters but my 2001 is white (or what Nissan calls white). My previous two Maximas were Arctic White!
if the lights in the spoiler are LEDs, that's your problem. LEDs don't use as much electrical current and the car monitors how much current is being used. When you disconnect the rear window light, less current is used. Less current equals burned out bulb to the monitoring system. The solution is to get a resistor and solder it across the wires in parallel to the LEDs. I forget the value of the resistor needed, but if you go to a web site that sells LED bulbs, they will have the info and probably also sell them.
Uploaded with ImageShack.us
I gotta ask.. What's up with aftermarket spoilers looking like they're installed too far up?? I know a spoiler isn't really effective unless going a certain speed around a corner or something but how does it make sense installing it 3-5 inches further up on the trunk lid? Do my eyes deceive me?
JWatZ - If the spoiler uses leds, you will probably have thesame problem as the other posters had when you unplug the parcel shelf light.
Yoshimitsu - It's a decorative thing, not functional.
Planning on pulling it out when the wifey gets back. If it kills the spoiler light I'll just leave it connected. Can't hurt to have four brake lights, right? Four excuses for someone not to rear-end me!
. Now only if I can find this kind of deal on a painted front lip!
MaxLife17
Jun 27, 2019 01:37 PM
