AE kit vs Stillen aero kit??
i have an AE maxima with the AE kit....i like how my car sits to the ground....but i wanted to know how much lower my car will sit with a stillen aero kit compared to the AE kit?....basically...how much lower is the stillen aero kit's front end compared to the AE front end?...an inch maybe?.....thank you...
albert
albert
Originally posted by Greg's2kGLE
It's all an illusion, I think Y2KevSE has actuallly measured this. It is probably less than a 1/4" thich (the Stillen kit). The AE kit maybe a little thicker, but probably not by much.
Originally posted by rob van dam
im confused..basically i was asking....how much lower off the front bumper does the stillen aero lip sit?....thanks
I said it isn't that thick, so i'd say a 1/2" is pushing it. Or are you talking about how much more it sticks out (horizontally)
Originally posted by serin
i think what he means by 'thickness' is a height measurement of the lip. ergo, the stillen lip would hang roughly 1/2" below the mounting point on the bumper. i certainly looks lower to me tho.
Originally posted by MyownNismo
I personally like the stillen kit then the AE kit becuase it looks bigger. If you want compare the two kits just lower your car the same height as Y2Kevse's and look at the difference. Your car looks great with the AE kit, but I personally think it would look better with the stillen kit. It's just my opinion and it's your car.
my car is as low as y2kevse's car....i have ground controls just like him...and i slammed it...i also have 18" rims....but i cannot tell the difference very well from pics....ummmmmm...oh well...i might get the stillen anyway.. ..and sell the AE
now, for how much lower to the ground they are and how much further they drop the car's overall stance, that would be an intelligent thing to ask.
if you knew anything you'd know that the kit will sit no lower on the bumper; no matter what kit. There all still mount at the same place basically unless you do a full fascia replacement.
here is something me and svttodamax(gabe) did today . . .we measured the height off the ground. our point of contact was the front of the car and in the center. gave has the jic coilovers on 10 setting and he was about 4 1/2 or 4 1/4 off inches off the ground and he has a 2k1 ae, and i was 5 1/4 off the ground and i have eibach/tokico and the stillen kit. . .he also has 18" and i'm on stock 16" se rims. . .if that helps any. . .
with the Stillen Touring front lip, the front of the car is just about as low as the stock..if not just little bit lower.
but the side towards the wheelwell is much lower than stock bumper..at least 2 inches if not little bit more. just think of it as the kit curving up towards the front.
Re: Questions...
Originally posted by spta97
...does anyone know the answers to these?
1) How much for each of the 2 kits?
2) Does the AE kit fit on a 2k3?
3) Can you use mud guards with the side skirts on these 2 kits?
Thanks!
Thanks!
2. No.
3. No.
Re: Re: Re: Questions...
Originally posted by myktek
i thought the AE kit u could see/use the mud guards....or am i wrong?
Greg's2kGLE was right, it is an optical illusion that the Stillen kit hangs lower. The kit sits right on the bumper and bulges out. If anything, there might be a 1/4 inch difference in height compared to having no kit at all.
Hope that helps, Albert
Pied
09-26-2015 03:29 PM
