need help removing MAF sensor from housing
Old Dec 28, 2002 | 12:50 AM
serin's Avatar
what's the name and size of the key i need to remove the actual sensor from its housing? i looks exactly like the on on timw's HID security bolts but a size or two smaller. kinda like a torx bit but with that nubbin in the middle.
and of course, i'm assuming i can find this thing at most radio shacks right??
thanks guys.
Old Dec 28, 2002 | 10:08 AM
adman's Avatar
Re: need help removing MAF sensor from housing
I got my set from Harbor Freight. They were about $12.00 for a 12 piece M/F kit. If you can't find the ones with the litte hole in the center, you can either make one yourself by drilling out the center of a torx bit...or, simply drill off the little "nipple" on the MAF bolt and use a regular bit. You can get individual drivers at AutoZone/PepBoys. I believe the size was a #9 if not mistaken.
ADMAN
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
