15 in wheels on a 2000 SE
Old Jan 4, 2003 | 09:02 PM
Tom2891's Avatar
I bought a set of 1996 15in Maxima alloy wheels and installed them on my 2000 SE (in place of factory 17in wheels). The change was to accomodate snows for the winter. They went on fine and feel fine but I am hearing a scrape when I back off the throttle. The sound goes away when I hit the brakes also. Any ideas what could be causing the problem?
Old Jan 4, 2003 | 09:32 PM
2k2kev's Avatar
It's chrome alright...
Re: 15 in wheels on a 2000 SE
are you sure your brake pads aren't getting worn down and you just started paying closer attention because of the new wheels? Check your brakes, it may be the warning that your brakes pads need to be replaced.
Old Jan 5, 2003 | 04:04 AM
Tom2891's Avatar
Re: Re: 15 in wheels on a 2000 SE
Sound I am hearing is similar. I had the brakes checked about a week ago when the car was serviced. The pads are about half worn.
Old Jan 5, 2003 | 03:13 PM
WizzaMax's Avatar
a couple things come up...make sure there is not something rubbing from the caliper to the inside of the rim
as well have you found out if it is noisier from one side more than the other?...or front to back?
as well can you swap the wheels back and make the noise again?
these may help figure out the causes...good luck!
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
