timing advance
Old Jan 6, 2003 | 01:39 PM
hombre's Avatar
timing advance
To all who have advanced their timing:
Did the timing get reset after a battery change/ecu reset? Or should it stay advanced forever?
Old Jan 6, 2003 | 06:10 PM
Galo's Avatar
Maxima Pilot
Good question...dunno...have not had either
a battery replacement nor CPU reflash/upgrade -and I intend not to need either for at least a dozen or more months!
Old Jan 7, 2003 | 06:35 AM
hombre's Avatar
Re: Good question...dunno...have not had either
bump...anyone know the answer to this? don't want to waste $50 on this if it will be reset if i disconnect my battery at some point.
Old Jan 7, 2003 | 08:11 AM
njmaxseltd's Avatar
If the parameters are stored in an EPROM, then no they will not change until the EPROM is reprogramed again.
An EPROM is an Erasable, Programable, Rear Only Memory chip. That means it needs to be reprogrammed to change any stored values. Disconnecting the battery does not reprogram or erase an EPROM chip.
Old Jan 7, 2003 | 10:42 AM
foodmanry's Avatar
Da Roller Coaster!
One way to find out is to have the technician advance the timing, then at that point disconnect the battery, and have him check the timing once you re-connect the battery. I'm sure if you do all this within one stop then you will not be charged extra. If the timing went back to OEM specs after disconnecting the battery then you can have him advance it again.
Old Jan 7, 2003 | 10:55 AM
hombre's Avatar
Doesn't it take up to 24hours sometimes to reset the ECU?
Old Jan 7, 2003 | 11:05 AM
Galo's Avatar
Maxima Pilot
If it does take 24 hrs, why be u worried? R U
gonna take 24 hours to replace a battery if it fails on u?
Old Jan 7, 2003 | 11:30 AM
foodmanry's Avatar
Da Roller Coaster!
Lots of discussion about resetting the ECU. Some say 24 hours, others say press the brake pedal after disconnecting the battery to drain all the power.
I recommend disconnecting the battery and pressing the brake pedal until you dont see the brake lights any longer. Then reconnect the battery and check the ECU to see if the timing has a changed from your previous setting.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
