Labor hours for clutch replacement
Old Jan 7, 2003 | 04:23 PM
whitam
My dealer is stating 8 hours labor to replace the clutch disc, pressure plate, release bearing, and flywheel. Does this sound accurate? 44K miles on my 2000, I can't believe I need a !#@$ clutch already....this is the flagship? Yeah, I'm peeved....
Old Jan 7, 2003 | 04:32 PM
Jeff92se's Avatar
I'm needing a caw
That's what their labor book probably says. If I had access to their lifts and special tranny jacks(or even without), I could probably do this in about 6 hours.
What's happening is they will charge you the "book" rate and time. But since the tech has probaly done this already about 10 times on other maximas, he could probably accomplish it alot sooner. So they will charge you for 8 but do it in 6 or less. Put two guys on the job and it does down to 4 hours or less.
Old Jan 7, 2003 | 06:26 PM
Blackgums100's Avatar
Jeff's ballpark is about right.
a good mechanic could do it between 4 and 6 hours. Generally speaking you should try and stay away from the dealership.
CorollaULEV
30
Aug 9, 2021 08:11 PM
CRizz
41
Jun 7, 2021 05:42 AM
MattWithTheMaxima
Jun 30, 2017 01:06 PM
FlaMark
25
Aug 28, 2015 10:15 AM
vanebecker
Aug 17, 2015 08:24 PM
