Wire taps and dielectric grease
Old Jan 8, 2003 | 06:49 AM
spta97's Avatar
In one the posts detailing the instructions for installing a shift light, they mention to use dielectric grease when using a 3M wire tap on the tachometer wire. I did some research and it looks like dielectric grease is meant so parts don't fuse together under extreme heat (ie: spark plugs and wires) but does it have conductive properties?
I ask because I have a loose connection (in my stereo setup) that I was using a wire tap and I wonder if dielectric grease would help conduct the electricity if the wire tap were to loose contact with the wire?
Anybody use this stuff?
Old Jan 8, 2003 | 07:18 AM
kramerica72's Avatar
Re: Wire taps and dielectric grease
Dielectric grease is great stuff. It's main use is to prevent corrosion and help maintain a reliable connection. You would be amazed how easy it is to take a plug wire off a year or so after using this stuff. You can use it on any electrical connection.
But in reference to your question, if you completely lose contact with a wire, nothing is going to help you.
Old Jan 8, 2003 | 07:50 AM
spta97's Avatar
Re: Re: Wire taps and dielectric grease
Thanks for the reply, BTW - I love your user id!
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
