PR CAI Dyno Results
Old Jan 9, 2003 | 03:47 PM
studman's Avatar
PR CAI Dyno Results
Hey. I've finally gotten the Max dyno'd. The results of the PR CAI were as follows.
HP was increased +4 HP.
Torque was increased +20 ft/lbs.
How this happened? I dunno. I don't have the stock dynos available anymore, so I can't post the actual dynos for the stock run, but you can compare them with other runs just for a rough guestimate.
Results from the best of 3 runs:
Max HP = 209.89 @ 5000 RPM (SAE Adjusted)
Max Torque = 238.13 ft/lbs @ 3350 RPM (SAE Adjusted)
Temperature = 74.3 °F
Barometric Pressure = 29.92-0.39 in.Hg.
Altitude = 96 ft
Correction Factor = 0.99
DynoJet Model = 248E
Click here for a link to the scanned images of the results
Edit: The numbers have been adjusted slightly as I now have the results rounded to the nearest hundredth instead of tenth.
Old Jan 9, 2003 | 03:52 PM
celica's Avatar
thats alot of torque
Old Jan 9, 2003 | 04:23 PM
BigDogJonx's Avatar
Good amount of torque for sure.,
Old Jan 9, 2003 | 05:06 PM
KL99SEA's Avatar
Are you sure you stated the RPM's correctly? Peak HP is at 5000 and peak tourqe is at 3000 I hope. Peak HP at 3000 is not right.
Old Jan 9, 2003 | 05:41 PM
slickrick's Avatar
Re: PR CAI Dyno Results
Max HP = 209.0 @ 3300 RPM (SAE Adjusted)
Max Torque = 239.7 ft/lbs @ 5000 RPM (SAE Adjusted)
Altitude = 96 ft
so how does this measure up to the nissan hp/tq ratings?
Old Jan 9, 2003 | 08:06 PM
Dave B's Avatar
Not DAVEB the parts guy
That's a ton of torque!!!
It is surprising how flat HP stays from 5000-6100rpms and then falls off like an anvil.
Dave
Old Jan 9, 2003 | 08:16 PM
Maximam's Avatar
How is that?
Old Jan 10, 2003 | 08:09 AM
studman's Avatar
KL99SEA: Dislexia kicked in. I've fixed the numbers. Sorry about that.
Maximam: How is what?
The numbers are stated based on the dyno. I was very shocked to see the results as well. I thought that the HP was going to be higher than it was, and didn't think that the Torque was going to be as high. I think I may call PR and see if their dyno resulted in the same increase in torque. +20 ft/lbs of torque is a HUGE gain for just having a CAI and a Muffler. I'm also investigating other mufflers and cat-backs to see if there would be more gains there.
Old Jan 10, 2003 | 09:41 AM
Maximam's Avatar
That big of a torque gain from just a muffler/intake?
vqman
is that a normal torque gain for CAI?
-vq
Old Jan 10, 2003 | 09:58 AM
studman's Avatar
Maximam/VQMAN: To be honest, I don't know. I've got a call in to Place Racing to see if they yeilded the same gains as I did. If they didn't, then I don't know how to explain it. I do know this... I have a 2002 SE with the MAF from a 2003 SE. That could be part of the equation... but I'm not sure. The results were as much a shock to me as they are to you.
Old Jan 10, 2003 | 10:09 AM
Maximam's Avatar
Keep us posted
Old Jan 10, 2003 | 10:16 AM
vqman
if that's a normal gain, I might break down and buy one...
-vq
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
