Brake Boost in Cold Weather (2000)
Old Jan 23, 2003 | 11:37 AM
WhoDatMax's Avatar
For the second day in a row, my Max had absolutely no brake boost for the first few minutes. The pedal was as stiff as a board. It's been 10-deg here for a few mornings. The question: how do I know if it's the booster, master cylinder, or engine vaccum? The brake booster is about $700. Is this a problem that will get worse or will it just go away when it warms up a bit.
Old Jan 23, 2003 | 11:49 AM
kramerica72's Avatar
Re: Brake Boost in Cold Weather (2000)
Are you using your e-brake? Maybe the rear calipers are freezing on you.
Old Jan 23, 2003 | 12:43 PM
WhoDatMax's Avatar
Re: Re: Brake Boost in Cold Weather (2000)
Thanks for the response. I am not using the e-brake. I should also note that this condition only exists for a few minutes (I assume while the car warms up) and is then fine for the rest of the day - including when I leave work after parking it for about 8 hours.
Old Jan 23, 2003 | 12:47 PM
Re: Re: Re: Brake Boost in Cold Weather (2000)
The only guess i could venture is maybe your booster is not holding vacuum and needs a minute or so to build up pressure...
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
hozay99
Sep 19, 2015 10:20 PM
ballerchris510
Sep 11, 2015 05:29 PM
ef9
Sep 10, 2015 10:35 PM
