Problem with sunroof 2002 SE
Old Jan 27, 2003 | 04:36 AM
cmr72's Avatar
Did some work on my max this weekend - kept factory radio but added MB Quart 6.5" separates up front and MB QUART 6.5" coaxial in back, Alpine V12 4 channel and Alpine V12 1/2 channel for the sub. Coincidentally, my sunroof doesn's slide anymore, but it does tilt. Was wondering if anyone knew if this could be related to the work in the doors??? There was a real tricky connector going through the door sill - I bent a pin and the passenger door wouldbn't lock (obviously I fixed that).
I had an issue with the switch sometime before when I originally picked up the car - the sunroof sometimes didn't open right away - but I am spooked now. Before I bring it in I was looking for some tech advice as to what it may be - Bad switch???
Old Jan 27, 2003 | 04:57 AM
Y2K2Driver's Avatar
Re: Problem with sunroof 2002 SE
If you disconnected the battery, then you need to go through some procedure (listed in manual ?) to get the sunroof to operate correctly again.
Old Jan 27, 2003 | 05:01 AM
cmr72's Avatar
Re: Re: Problem with sunroof 2002 SE
Tha's amazing - how the hell could a consumer possibly know that???? To confirm, the tilt function would work though?
Old Jan 27, 2003 | 05:32 AM
92 SE-R 02 SE
I dont think this is true. WHen i put my intake on i disconnected the battery and the roof works just fine.
Old Jan 27, 2003 | 05:53 AM
cmr72's Avatar
Re: Re: Re: Problem with sunroof 2002 SE
Kudos to Y2K2Driver,
http://www.smartnouveau.com/Sentra-Pathfinder.pdf - PAGE 16:
Sunroof Memory Procedure: The electronic sunroof memory (which tracks sunroof position) is erased whenever the battery is dead or has been disconnected. The memory must be reset when the battery power is restored. To reset the memory:
1. Turn the ignition switch ON
2. Close the sunroof (if open)
3. Open the sunroof to the vent position. Hold the switch ON until a "bump" is felt in the sunroof motor. This action resets the sunroof memory.
4. The sunroof is now ready for normal operation.
Old Jan 27, 2003 | 08:33 AM
saxdogg's Avatar
Re: Re: Re: Re: Problem with sunroof 2002 SE
[/B]
Interesting, if your sunroof is not responding, how can you follow these instructions? I;ve heard of the disconnect the battery idea before though...
ARFF
Old Jan 27, 2003 | 09:55 AM
maximilion's Avatar
This happened to me on two occassions and it wasn't because of a disconnected battery or anything like that. After minutes of trying to figure it out, a 14 year old girl did it. I don't know exactly what she did, but it was just a combination of tilting the sunroof and playing with the open/close switch.
Works fine now.
Old Jan 27, 2003 | 10:36 AM
Hraesvelg's Avatar
I had the same thing when I put in my MQ Quarts! Maybe it's the speakers? Anyway I took it to the dealer and set up an appointment, and on my way back home it started working. I just played with the switch and it works fine. the dealer said it was something about resetting the memory...
Old Jan 27, 2003 | 11:17 AM
ajahearn's Avatar
I believe the issue with the sunroof occurs if you have left the sunroof open (or tilted) when the battery is disconnected. If the sunroof is closed when this happens then it will work properly. This kind of makes sense as its probably forgotten what state the sunroof was in and when power is restored it assumes the closed condition.
Old Jan 27, 2003 | 11:32 AM
BioMaxDDS's Avatar
I don't thik its the battery. I used to have this problem every once or twice in a month. I think its the motor unit for the sunroof that's defective or not making a very good connection. The dealer replaced the motor...and it works fine now. its not the battery
Old Jan 27, 2003 | 09:13 PM
madball22's Avatar
I had the same problem with mine. The vent was working but it wouldn't slide open. I dropped it off at the dealer and came back a few hours later. When I picked it up they said that it was working fine and they didn't do a thing to it. Maybe if you drive by a Nissan dealership it will fix itself too.
Old Jan 27, 2003 | 09:15 PM
BioMaxDDS's Avatar
you know what, that actually happened to me too. Its was like the third time when I went back that it finally stopped working. the first 2 times went i went into the dealer, for some reason when they touch it, it worked fine
Old Jan 27, 2003 | 09:41 PM
Ma><iManiac's Avatar
The only problem I have had with my sunroof is the damned wind visor.
Old Jan 28, 2003 | 04:03 AM
cmr72's Avatar
It's working now - thanx everyone
The instructions from Nissan on how to reset the sunroof solved the problem. Thanx for looking out.
Mar 12, 2020 12:06 AM
Vequity
Sep 10, 2015 05:26 AM
Colossus
Sep 9, 2015 05:46 AM
GregL65
Sep 7, 2015 10:33 PM
mikebla
Sep 3, 2015 05:37 PM
