Variable intake question for 2000 SE
Old Jan 27, 2003 | 07:49 PM
VG30DE's Avatar
OK, 2000 maixma SE 3.0, I look at the upper intake maniflod and I see that vacuum/electric solenoid that activates the intake manifold "flapper" inside that opens it up at 5000 rpm for that nice boost in power and the change in intake sound. My question is: can I make that thing open at 4000, or even 3000 RPM so that when I get on it, the power is there already. Maybe switch activated even? Is it activated by vacuum or ECU signal? Is there maybe a product on the market to control it along with the VTC? Thanks for any info.
-Mike
Old Jan 28, 2003 | 03:30 AM
RBa's Avatar
RBa
Re: Variable intake question for 2000 SE
-Mike
Let's say you do manage to engage the VI earlier, it just means you'll loose more power towards the high end..
There's a reason why they raise the top speed on the 5thgens..
Old Jan 28, 2003 | 05:08 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
The primary runners give optimal performance before 5000rpm.
Opening the secondary runners gives optimal performance after 5000rpm.
Opening the secondary runners before 5000rpm would probably actually cause you to lose power, not gain it.
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
