Another Dynamat Install (Rear deck ported?)!!!!!
Old Feb 12, 2003 | 09:13 PM
WildmanAL's Avatar
Check out my home page http://maxima.cardomain.com/member_p...=231559&page=3
Another dynamat install completed. Worked wonders and I recommend anyone with subs to do the same. It's not really "dynamat" but a material called FatMat. I got 100 sq feet off ebay for $100. Took me about 47 sq feet to do my trunk, and soon I'm doing my doors with the rest.
http://cgi.ebay.com/ws/eBayISAPI.dll...003751042&rd=1
My question is:
Has anyone ported their rear deck? I've seen one max that did it, but they had a custom rear deck built. All I'm doing is using this link http://zachaltman.hypermart.net/Rear-deck.htm to fix my rear deck, then I'm cutting into the rear deck and placing a port piece in the hole to make it look nice. By having my rear deck slid down the seat belts sitting in my back seat. I'm Exposing the bare metal and that huge hole from where the bose sub should be. The hole allows the subs to breathe better, making my bass sound better. I'm planning on putting about a 5" round port hole. Will that be big enough? What would anyone else consider doing?
Highest appreciation
Old Feb 12, 2003 | 09:45 PM
BLaZin 2k MaX's Avatar
Good job! Do you have the rear deck speaker if not you can cut that hole out and use the speaker grill and that would be a perfect port. That is actually what im going to do, but I just need to find that speaker grill from somewhere.
Does that stuff you put in stink as bad as ppl say it does? I have dynamat and their is no odor at all.
Old Feb 12, 2003 | 10:00 PM
WildmanAL's Avatar
What's up BLaZin 2k MaX
Have you tried going to the dealership asking them about the bose grill? Originally that was what made me think about porting the rear deck. If I get the grill or not, I don't really care because I'm just going to keep the hole open. It will be done in 1 1/2 weeks when I go home from college to work on the rest.
The FatMat does smell, but not bad at all. You notice the smell right when you get into the car, but you eventually get used to it. It smells like asphalt if that helps any. BLaZin 2K MaX you were the one that made me do this mod. Thanx again
Old Feb 12, 2003 | 10:10 PM
Im glad I motivated you to do this mod even though you didnt use dynamat xtrem. Im gonna go check the dealer tomorrow, any clue how much the grill costs?
Another question, I see that you have a ported box, have you always had your box ported or did you change? If so what kind of diffrence did you find? I like your ported box, nice and simple exactly what Im looking for.
Old Feb 12, 2003 | 10:34 PM
02'maxed-out's Avatar
I recently went to Home Depot to look for some product called "Peel and Seal" that an org member described... Didn't quite find the exact peel and seal, but another product which sticks on one side and has the aluminum face on the other side, kinda like dynamat... the stuff cost like $15.oo but sorry didn't get the square feet, but most likely 3 rolls for the trunk... i didn't buy it, but anyone withsome suggesstion please help... thanks...
Old Feb 12, 2003 | 11:25 PM
2kSeattleMax's Avatar
I used Peel-N-Seal. Its available from Lowes. Think you get 25 square feet for 10 bucks. Same stuff as Dynamat from what I've seen.
Old Feb 13, 2003 | 06:18 AM
releasedtruth's Avatar
rilla dope
Re: Another Dynamat Install (Rear deck ported?)!!!!!
Just wait, fatmat comes up after a couple months. It feels like glue at the start, but pieces will just loosen up and fall off after a while. It's great where it works and where it doesn't, it falls off like Willie Nelson and the wagon....
Old Feb 13, 2003 | 06:48 AM
WildmanAL's Avatar
I have no idea what the grill is going to cost and for the ported box. I've always had a ported box, It allows these subs to move their 2" safely. I used to have a port on the side of another box, but when I got this car, I got a new box, moving the port hole. And for releasedtruth. I don't exactly know where you're going with your post, but this Fatmat stuck very nicely and when I did mess up, it wasn't easy to full back off.
Old Feb 13, 2003 | 08:23 AM
PoLo's Avatar
2-Wheelin it...
Re: Re: Another Dynamat Install (Rear deck ported?)!!!!!
i've got a full roll of cascade VB-3 waiting to be installed. that's some scary stuff. 2 layers of foam w/1 layer of pure lead in between.
Old Feb 13, 2003 | 09:24 AM
Just don't chew on it polo.
Old Feb 13, 2003 | 09:48 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I just got mine yesterday, I think it was a little over $20 from DAVEB.
Did you guys use foam to silence the rear deck rattles? If so, how thick is it and where the heck did you get it?
I need some bad!
Old Feb 13, 2003 | 09:49 AM
2k2MerlotSE's Avatar
JUVIN's ride
My question is:
newbie question:
what do you mean by porting the rear deck? My guess a tube like piece from the hole on the rear deck down to the sub....am I close
Old Feb 13, 2003 | 09:51 AM
IceY2K1's Avatar
Re: Re: Re: Another Dynamat Install (Rear deck ported?)!!!!!
What are trying to do, elude the X-ray machine at the border or something?
Old Feb 13, 2003 | 09:53 AM
WildmanAL's Avatar
Are you going to put that between the rear deck? How good did that stuff you put in your doors work? My doors rattle now.
PoLo's Avatar
2-Wheelin it...
Re: Re: Re: Re: Another Dynamat Install (Rear deck ported?)!!!!!
hahaha
well i'm goin Diamond Audio TDX 12's (a pair; 600W into each from a D5-1200.1) in the trunk, so i felt my trunk rattle would be way beyond what some regular mat would cover.
i guess i'm just being safe. that and i'm impressed with cascades quality material. i used their spray on my doors and i noticed less noise in the cabin just from doing the front doors.
Old Feb 13, 2003 | 09:56 AM
PoLo's Avatar
2-Wheelin it...
i plan on doing the trunk lid, rear, sides, and with what's left over, do the trunk floor. the rest, i plan on getting cascade VB-2 or VB-5. not as strong as VB-3 and not as expensive, but i feel that the areas mentioned above are the major causes of trunk rattle. everything else just needs a little stiffening, which is where the VB-2 or VB-5 comes in.
door picture done in cascade spray:
Old Feb 13, 2003 | 09:58 AM
WildmanAL's Avatar
Originally posted by 2k2MerlotSE
newbie question:
That's right.
[QUOTE]Originally posted by IceY2K1
[B]
That's DAVEB from courtesy right? Do you have a link or an item number?
Old Feb 13, 2003 | 10:31 AM
IceY2K1's Avatar
He's at Maxwell Town North in Texas. Call him at (800)251-7278.
Old Feb 13, 2003 | 11:34 AM
Right on thanks for the number I need to get one of these asap. As for the rear deck all I used was like a sheet of dynamat xtrem and it did the job but playing my system all the time kinda go to it and I hear slight vibrations in the back but im sure ill fix it.
Old Feb 13, 2003 | 12:20 PM
xtantmaxima's Avatar
you mean like this???
Old Feb 13, 2003 | 01:08 PM
WildmanAL's Avatar
No I'm not porting the box into the car, just putting a hole (much smaller) in the rear deck for air to blow out.
Old Feb 13, 2003 | 02:47 PM
HondaKilLR's Avatar
Looks Sick man. I Looooove Xtant!
Old Feb 13, 2003 | 04:11 PM
IceY2K1's Avatar
Daaaaaaaaaaym!
Now that's a port!
I'm just cutting the same hole the BOSE guys have and using the grille to make it look nice and purrrrdy.
Now where the heck do I get the foam?!?
Old Feb 13, 2003 | 04:37 PM
Thanks, so do I . Now, if there ever is an Indy Meet then you can see it in person.
Old Feb 13, 2003 | 07:29 PM
BLack2k2MaX's Avatar
let me know how much the rear bose grill costs if anyone found out... im interested in doing a port for the rear deck... i installed the dynashield spray today and the cascade vb3 all throughout the trunk but it still sounds baffled so i think im going to do a port...
Old Feb 13, 2003 | 07:39 PM
IceY2K1's Avatar
$17.19+shipping
Old Feb 14, 2003 | 06:40 AM
im interested in porting out the rear deck... how much does the bose grill cost and the part # ... i jus installed cascade Vb3 in my trunk today... works like a champ... but its a little baffled and the rear deck looks like it wants to jump off... so im gonna have to let the air out....
Old Feb 14, 2003 | 08:19 PM
Like stated b4 its 20 bucks from some guy named DaveB.
Old Feb 15, 2003 | 12:20 PM
does Dave B have a # i can reach him at does anyone know...
thanx
Old Feb 15, 2003 | 12:48 PM
Look through the whole post next time.
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Mcnabb34
Aug 11, 2015 08:45 PM
