Sub Swap help
Old Feb 17, 2003 | 02:02 PM
NikaL's Avatar
Sub Swap help
I want to swap my bose sub. However, I don't want to build a box. I really don't know anything about audio and need your help. Can I just remove a bose sub and drop Image Dynamics ID8 v.3? do I need to get an amp? if yes, what would you recommend? I searched, but all I'm getting is amps and subs with boxes build.
Any help will be appreciated. I really have buzzing coming from bose sub.
Nik
Old Feb 17, 2003 | 02:33 PM
BigDogJonx's Avatar
You cant do this without a separate amp. The bose sub has a amp built onto the sub. If you run that sub, make sure it works as a free air sub, otherwise it will do nothing for you.
Dixit
Old Feb 17, 2003 | 02:40 PM
NikaL's Avatar
Dixit
Thanks Man
Sorry if i'm asking too many questions. If I get a sub and 125 watt sum amp, do i just cut into rear speaker wires?
Old Feb 17, 2003 | 02:42 PM
NikaL's Avatar
Originally posted by NikaL
Thanks Man
did finish....
do i connect a new amp to the old boss sub wires?
Old Feb 17, 2003 | 03:12 PM
BigDogJonx's Avatar
Off the plug there are two wires you need to tap, black and white. They are thinner in gauge than the other ones. Those are the low level signal wires.
Black for +
White for -
Tap those two wires DIRECTLY to a cut end of patch cable. By that I mean take a patch/RCA cable, and cut an end off one side. Then connect the black and white wires to the cut end of the patch cable. That basically allows you to send the low level singnal directly to the amp using the patch cable.
Dixit
Old Feb 17, 2003 | 03:14 PM
2kSeattleMax's Avatar
I'm researching this for a friends TL. Diamond makes a simliar sized sub.
Make sure your sub is free air..since you are only running baffle in the rear deck.
I've heard the output from the factory bose might need some adjustment in order to go high level input into an aftermarket amp. Think Crutchfields has adapters...
This might be a better post in the audio forum. Good luck.
Old Feb 17, 2003 | 03:16 PM
TimW's Avatar
The silent but deadly Moderator
yeah, just be sure to check the subs specs.. infinite baffle 8" subs wont need alot of power. No need to run out and get a monster amp.. but you'll want something clean and accurate.
Old Feb 17, 2003 | 04:21 PM
juice's Avatar
Re: Sub Swap help
I switchd mione with an 4000w 8" Kicker Comp VR hooked up to a seperate amp and it sounds great. I highly recommedn it I also recommend some kind of sound insulation in the rear deck becasue it WILL rattle, I used spray foam from Home Depot and that deadened all the rattling.
Old Feb 17, 2003 | 04:25 PM
BigDogJonx's Avatar
Didnt knew they made a Four Thousand Watt 8" sub. I guess that blows away the 34" Audiobahn sub then.
Dixit
Old Feb 17, 2003 | 11:48 PM
TimW's Avatar
To be more exact, I've heard that you can drive an infinite baffle 8 from ID or JL with a punch 150 and still have 1/2 gain left. I've just read that, but plan to go that route soon.
heh, that 4000w 8" has a 300lbs magnet and a 4ft cone excrusion.
Old Feb 18, 2003 | 07:19 AM
woosh's Avatar
Did you say 4 0 0 0 w? I don't know how on earth you'll power that from your car. You will need something short of a portable nuclear reactor.
SHIFT_woosh
Old Feb 18, 2003 | 12:48 PM
NikaL's Avatar
What do you think about this? I'm gonna go with Juice's setup.
Kicker Comp 03C84sub, Sony XM-D400P5 amp and i'm gonna use PAC adapter kit?
It's gonna be aroung $350 plus shipping.
Old Feb 18, 2003 | 01:30 PM
TimW's Avatar
heh, that amp is pretty cool.. but really overkill for that sub in free air config. That recommended power is for sealed I bet. I would ask Kicker just how much amp is needed.
However, considering that the smallest quality amp will cost you $130-ish, you arent blowing too much money at 180. Better too much than too little. One positive for the amp you've chosen is the variable crossover. Most lower end quality brand amps will be fixed at 80hz. That might be alittle too low for this 8 and leave you will alittle midbass hole.
Old Feb 18, 2003 | 01:39 PM
NikaL's Avatar
Thanks Tim
WHat do you think aboutRockford Fosgate Punch 200M ?
Old Feb 18, 2003 | 02:41 PM
NikaL's Avatar
sorry
I'm asking too many questions. I just foud this tread http://forums.maxima.org/showthread....move+head+unit according to this I can tap into sub wire and run my amp from there. is this right?
Old Feb 18, 2003 | 02:46 PM
TimW's Avatar
as Dixit said above.. he's done it.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
