2002 automatic times
Old Feb 17, 2003 | 08:37 PM
LordHowe's Avatar
according to http://forums.maxima.org/showthread....2002+auto+time
a 2002 auto SE can run 6.7-6.9 in the 60. I was curious if anyone would have a good estimate of the 60mph time if i were to add the follow:
1. franken car intake with apxi filter
2. cattman y-pipe
the reason i'm asking this is that i know someone who has a BMW 330Ci automatic and they are suppose to run 6.7 - 7.0 and i was just wondering how close of a race it would be if i were to add the 2 mods to a 2002 auto SE
Old Feb 17, 2003 | 08:42 PM
Y2KSESteve's Avatar
You would get a pretty decent gain between the two. You should take the 330 pretty easy.
Old Feb 17, 2003 | 08:45 PM
Young04's Avatar
Re: 2002 automatic times
2. cattman y-pipe
where did you get high 6's for 0-60? most people on that thread seem to say mid sixes. i ran my 2k2 GLE at 14.827 down the quarter mile - this translates to a 0-60 time right around 6.5 seconds.
i know there are going to be people who disagree, but i BELIEVE that the general consensus is that from a stop, a 2k2/2k3 will edge out a 330CI, assuming the transmissions are the same.
adding a franken car intake should take away 1/10th, perhaps. to the best of my knowledge, cattman doesn't have a y pipe available for the late 5th gens, but someone correct me if i'm wrong. a few people have installed a warpspeed y-pipe with favorable results. combined with a b-pipe, it seems to add 15 hp at the wheels. with those two mods, you should knock off .3-.4 seconds 0-60 or the 1320.
Old Feb 17, 2003 | 08:52 PM
2k2kev's Avatar
It's chrome alright...
Re: Re: 2002 automatic times
Originally posted by Young04
young04, stop using such big words, smartie
lordhowe, you can look in the 1/4 mile forum and see if someone has similar setup to what you have...
Old Feb 18, 2003 | 12:21 AM
LordHowe's Avatar
Awesome!! how about in the quater mile race? how close are these two cars?
Old Feb 18, 2003 | 12:41 AM
Stealth Interceptor's Avatar
For your 1/4 mile time of 14.827, is this before or after mod? If this is after mod and you did manual shift your auto when accelerating, then I would say LordHowe is about right on 0-60 timing of 6.7-6.9 sec.
I also read somewhere (C&D?R&T?MT?) that Infiniti I35 auto stock (about the same hp as, but heavier than, 2k2/3 Max) 0-60 timing ranges from 6.9 to 7.3 sec? and somewhere on this board that 2k2/3 auto stock 0-60 timing is about the same as 1995-2001 manual stock, which is around 6.6-7.0 sec? Both seem to confirm that 0-60 for 2k2/3 auto stock is in the upper-mid six secs....
Old Feb 18, 2003 | 03:56 AM
Blu's Avatar
Blu
the tits
mag racers I love em
Old Feb 18, 2003 | 05:02 AM
Young04's Avatar
Re: Re: Re: 2002 automatic times
aRf?
Old Feb 18, 2003 | 05:08 AM
Young04's Avatar
i agree with blubyu - don't mag race because they tend to be rather inaccurate, for a variety of reasons.
as to the 14.827 i was bone stock but i took all the crap out of my trunk (spare tire, jack). i messed with the tire pressures a bit, and i was on an 1/8th of a tank. conditions were very good - dry, october day in the 50's. i manually shifted around 6500K. car had 8000 miles on it or so.
Old Feb 18, 2003 | 06:41 AM
skandalouz's Avatar
Re: Re: Re: Re: 2002 automatic times
does manually shifting your automatic make it faster? i thought it slowed you down.... i have a 2k3 auto.
Old Feb 18, 2003 | 11:23 AM
lcf's Avatar
lcf
Re: Re: Re: Re: Re: 2002 automatic times
Yes.
Old Feb 18, 2003 | 07:46 PM
Virus's Avatar
yes
Old Feb 19, 2003 | 07:18 AM
Maximax2's Avatar
Yes, because most of our autos will shift at 6,200 (which, depending on who you believe, may actually be even lower because of tach error). This drops you farther down the powerband in the next gear, causing you to lose time.
By manually shifting you can change the shift point to 6,500 (or whatever you want, I guess, until you hit the rev limiter). I find shifting at an indicated 6,200 will make the shift happen at around 6,500.
Note that (also depending on who you believe) this may or may not be good for the tranny...
Old Feb 19, 2003 | 07:23 AM
Blu's Avatar
Blu
the tits
Re: Re: Re: Re: Re: Re: 2002 automatic times
I guess I will find out bc I have nailed the rev limiter plenty. i plan on droping the pan in the next 3k miles and replacing the ATF with synthetic. Hopefully I don't have to many metal shavings.
Old Feb 19, 2003 | 10:25 AM
LordHowe's Avatar
anyone would know how close of a race between the two cars in a quater mile? (automatic 2002 SE and triptronic(auto) 330 Ci)
Old Feb 19, 2003 | 03:20 PM
max...to the ma's Avatar
aRf?
what does aRf mean?
Old Feb 19, 2003 | 04:13 PM
slickrick's Avatar
a tiptronic should be a drivers race between the 2.
Old Feb 19, 2003 | 08:14 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
I believe the manual version of the 330 hits the 60MPH mark in 6.2 seconds. Figure at least .4-.5 seconds longer for the auto version. if it was a SMG, then you'd be screwed, but I don't think they offer the SMG in the 330 yet (or maybe they do, but I've never seen one with it).
Old Feb 20, 2003 | 05:21 AM
Larry's Avatar
Here's a formula to calculate your approximate 0-60 if you know your 1/8 et and mph: http://notabusinessracing.org/0-60_equation.html
Looks like my 0-60 is 5.37 based on my 1/8 et of 9.151 @ 78.31 mph.
Cotozic
Jun 28, 2017 08:01 PM
follyburr
Aug 12, 2015 08:57 PM
fastcarny
Aug 12, 2015 03:50 PM
yat70458
Aug 3, 2015 01:16 PM
