Does the Max engine use SFI or MFI?
Old Jan 9, 2001 | 11:16 PM
MaxMus's Avatar
Sequential Fuel Injection or Multiport Fuel Injection. Which type of fuel injection system does the engine use?
Old Jan 10, 2001 | 07:08 AM
max2001se's Avatar
I believe it is a sequential fuel injection system or SEFI.
Old Jan 10, 2001 | 07:10 AM
MaxPerformanceSE's Avatar
What are the diferrences between the two?
Old Jan 10, 2001 | 10:04 AM
dvyuan
I think Maxima's since the beginning uses Multiport injection system. If you take a look under the hood there is a fuel injector for every cylinder. I think a sequential system only has a single injector that fires sequentially.
Old Jan 10, 2001 | 10:12 AM
Jeff92se's Avatar
I'm needing a caw
Well here it goes. Might be a mistake or two in here.
1st = constant fuel injection. circa very old Mercedes and old BMW. It injected fuel all the time.
2nd = TBI or throttle body fuel injection. Basicly a carb body w/ a single fuel injector. Fired when ever probably all the time too but at diff timing rates.
3rd = Sequential fuel injection: my guess. Injectors on each cylinder or maybe back on the manifold but might have fired twice per firing stroke instead of just once per firing stroke.
4rd = multiport fuel injection. Injectors on each cylinder. Firing only once per firing stroke. Basic design is still around even today. It's been around since the early or mid 80's.
Old Jan 10, 2001 | 10:37 AM
max2001se's Avatar
I think you may be right - but i thought both Sequential and Multiport systems had ports for every cylinder. Any one know for sure??
Old Jan 10, 2001 | 10:39 AM
max2001se's Avatar
OOPPS!
Sorry 'bout the multiple posts. My mouse is faster than me:P
Old Jan 10, 2001 | 10:44 AM
Jeff92se's Avatar
I'm needing a caw
Re: OOPPS!
You can delete your own posts! Look for the edit/delete feature.
Old Jan 10, 2001 | 10:46 AM
max2001se's Avatar
Re: Re: OOPPS!
thanks
Old Jan 10, 2001 | 12:08 PM
2000MaximaSE's Avatar
Nissan should advertise what they use by putting an emblem on the car like crappy american car makers
Im glad they dont stick a v6 emblem on them either like honda or any american car maker does..
Adam
Old Jan 10, 2001 | 03:39 PM
MaxMus's Avatar
go to
http://www.howstuffworks.com and read the article on fuel injection. sequential fuel injection fires individually I believe, while multi fuel injection just fires when a revolution of the crankshaft occurs.
both types of injector technology includes an injector per each cylinder. that info may not be entirely accurate, so check the website.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
