Anyone using hood struts on CF hoods?
![](https://maxima.org/forums/images/smilies/motm_header.gif)
![](https://maxima.org/forums/images/smilies/support.gif)
I don't know what you other guys use but ever since I had my cf hood I just use like a think steel pipe to hold the hood up. I know the cf hood is too weak for the stock hood struts. What does everyone else use?
I used the hood struts w/ my vis hood and it works fine. Only thing, my hood doesn't close all the way right now. I don't think the latch is locking. I have hood pins to hold it down. There's about a quarter inch gap. How does your hood fit? Do u have that problem?
Thanx,
Lam
Thanx,
Lam
Thanx,
Lam
Thanx,
Lam
I use the Hood struts with VIS..and no problems ..
hmm.. for latch, you should lift them a little, then CFH will close fine... I had that problem too, but be careful when u raise the latch... other than that..my hood is fine!
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
ok guys,
I just got my VIS and installed it a week ago. I have been using a board that has been working perfectly to hold my hood up. Where did you guys drill for the hood struts? My hood has a spot on each side (a little indentation that looks to be in the same spot as the OEM hood stru mounts) but I am not sure. Is that where you guys drilled?
ok guys,
hey like your new brake ^^
Originally posted by MaxDoogie
ok guys,
ok guys,
I drilled on the same spot and it works perfectly fine~
i checked your brake mod.. awesome man!
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Re: hey like your new brake ^^
I just finished the install of the brakes last night, and they look even better on the car then they do in the pics that I have up now
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
I'll be updating real soon with more pics of the hood, the brakes and my new leather seats
Originally posted by Y2KevSE
How did you guys reinforce the bolt from the strut that's going into the hood? No washer and nut on the other side?
I'm using The Club to hold up the hood.
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
The original stut had no type of reinforcement on the other side of the hood...Then again, the metal is a little stronger than the fiberglass
Oh well, I guess I will be heading to the local parts store to see if they offer any type of weaker struts that would work with our hoods...Maybe struts from a 240sx or something...
heheh...I was just about to send you a PM to see if you got the hood struts in yours...I figured someone that could do a turbo upgrade could do hood struts no problem
:wall
The original stut had no type of reinforcement on the other side of the hood...Then again, the metal is a little stronger than the fiberglass ;-)
:wall
Hehehehe..... I haven't done this yet because I question the integrity of the fiberglass reinforcement. Have you tried pushing down on the hood struts?!?!?
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
For now, it's The Club or some springs.
![Wiggle](https://maxima.org/forums/images/smilies/wiggle.gif)
Now imagine putting all that pressure (~ 1/2" area per strut) on the hood. Personally, I'm not comfortable yet until a weaker hood strut or some other reinforcement is found.
Even though the board I have now is a perfect fit, I still want something else
I'll let everyone know if I find anything
AaronL
08-08-2020 10:31 AM
Unclejunebug
04-02-2016 05:42 AM
