Upgrading tires-Need sizing help
Old Mar 10, 2003 | 09:16 AM
Rgamfn1's Avatar
Okay I'm finally getting rid of the OEM tires and I'm upgrading to the Sumitomo HTR+'s. These appear to be equal or better in the snow than the Michelin Pilot Sports, and they're cheaper. My question is what size is accurate?
Tirerack says I should get 235/45/17, but according to a size calculator it says the 245/45/17 is closer to the stock tire size (only .7% faster).
Also these tires are supposedly made for 7.5-9.0 rims with the recommended width at 8.0. Will they fit well on our 7" width rims?
What happens when I upgrade the rims, will the tires fit well on another set of 17 x 7 rims or will I need to move up to 17 x 7.5 rims?
Old Mar 10, 2003 | 09:22 AM
jjs's Avatar
jjs
Re: Upgrading tires-Need sizing help
FAQ time.
Old Mar 10, 2003 | 09:46 AM
T-bone's Avatar
That tire size calculator is accounting for the radius and not the width. 245 is way to wide for a 7" wide wheel. Like JJS said, 'FAQ time'.
Old Mar 10, 2003 | 09:57 AM
Rgamfn1's Avatar
Ohhhh! Okay, I understand.
BTW, when you say FAQ Time you might want to specify FAQ (top of the page) from MAX FAQ (on home page)
Thanks for the help though.
Old Mar 10, 2003 | 10:01 AM
Donkey®'s Avatar
wat
You got off easy...Normally you would have had 'SEARCH' shoved up your a$$.
Old Mar 10, 2003 | 10:03 AM
Rgamfn1's Avatar
I tried that 'Search' still isn't working for me.
Old Mar 10, 2003 | 10:07 AM
Donkey®'s Avatar
wat
That is why I said you got off easy. They can't force 'SEARCH' on ya if it ain't working.
Old Mar 10, 2003 | 10:13 AM
ohboiya's Avatar
I say keep search disabled indefinitely then ...
Old Mar 10, 2003 | 10:28 AM
PCGuRu2K's Avatar
If you are choose between those two sizes. Get the 235/45/17. Those will fit the x7.0 width of a rim. 245/ is just too wide. There are a lotta arguements saying that ppl with stock 17x7 rims should get 225/... and not 235 cuz it's wider. But don't worry just get the 235. You should be fine even if you take corners hard.
vito1281's Avatar
The new thing will be "Look up the FAQ". Not to get OT here, but c'mon guys, if people didn't ask the same questions periodically, this forum would have 1 to 2 posts a day. Cut people some slack.
Old Mar 10, 2003 | 10:45 AM
kronnman's Avatar
It works for me...
Old Mar 10, 2003 | 10:50 AM
vito1281's Avatar
Originally posted by kronnman
It works for me...
Das cuz u donated $$$!
Old Mar 10, 2003 | 11:04 AM
kronnman's Avatar
Old Mar 10, 2003 | 02:15 PM
Wasim521's Avatar
I thought the OEM tire size was 225/50/17...what would be the advantages of going with something that's not so radically different?
Old Mar 10, 2003 | 06:16 PM
PCGuRu2K's Avatar
Wider and lower profile tires increase handling and stability.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
