What size spacers?
Old Mar 11, 2003 | 09:47 PM
BLaZin 2k MaX's Avatar
What size spacers?
I have 7.5" wide rims and I want them to sit flush with the body what size spacers do I need to get? Also if anyone has done this pics would help. THanks
Old Mar 11, 2003 | 11:09 PM
irvine78's Avatar
Re: What size spacers?
well, it kinda depends on your offset...with 40-42mm offset rims, you'll need about 10mm spacers to flush them out. get the H&Rs...or better yet, just get wider rims..
Old Mar 11, 2003 | 11:59 PM
20th maxstyle's Avatar
Never use spacers. Metal and force cause the spacer to crush and can cause toe and/or camber damage to tires. If the temp is right, they can also shrink, causing you lug nuts to be loose and fall off even.
Old Mar 12, 2003 | 12:48 PM
y2kse's Avatar
Does that mean that H&R Spacers are unsafe to use?
Old Mar 12, 2003 | 12:57 PM
MOBOY's Avatar
I have never heard of that before...I guess our stock hubs could just fall off too, or warp, or break studs. That is pretty crazy!
I have a set of 15mm HR spacers for sale...NIB. I was going to use them with some aftermarket rims but never got around to it. HR makes them 5mm and a 15 mm, but I don't recal finding 10mm spacers. The 15mm requires new lugs which are included. They are hub centric and should bring the tires about flush with the wheel well. 15mm is about 3/4" just so you know.
Old Mar 12, 2003 | 07:40 PM
How much you want for them?
Old Mar 13, 2003 | 06:36 AM
y2kse's Avatar
You've got mail, MOBOY.
Old Mar 13, 2003 | 12:32 PM
optimus1's Avatar
more like 5/8 inch ...
Old Mar 13, 2003 | 12:56 PM
MaxDoogie's Avatar
It's 0.590551 inches, or basically 3/5ths of an inch to be exact
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
