Pinging causing loss of HP?
Old Mar 15, 2003 | 07:53 PM
Titleistprov21's Avatar
I raced my friends 2001 Mustang tonight. 4.6 liter. LOST HORRIBLY! Are we supposed to keep up with them? My car PINGS like a *****. I bought knew sparkplugs today, But i couldn't install them because i didnt' have the right tools. I know that has nothing to do with the pinging, but my SES light wont' come on so Nissan won't service it. Please let me know what you guys would do if you had this problem. Thanks
-Pat
Old Mar 15, 2003 | 07:55 PM
Larrio's Avatar
The Definitive AE Master
Re: Pinging causing loss of HP?
-Pat
i don't think you'd hang with it anyways if you weren't pinging
Old Mar 15, 2003 | 08:13 PM
slickrick's Avatar
-Pat
did you race from a stop or a roll?
Old Mar 15, 2003 | 08:21 PM
jimz02max's Avatar
Depends on the driver! HP and weight of cars would equal or come close....I think!
Old Mar 15, 2003 | 09:27 PM
2kSeattleMax's Avatar
Your pinging is coming from a bad coil(s). Go hit the TSB and FAQ stickie on your way to the dealership.
Good luck!
Old Mar 16, 2003 | 06:58 AM
I've brought my car to Baystate Nissan and told them about the pinging. They claim bad coils has nothing to do wiht engine pinging. We raced from a stop, and roll. He beat me everytime, and im a better driver than he is. I have greddy, and frankencar. Will the shop replace my coils even though my SES light isn't on? I can buy the coils at wholesale, but is it hard to install? Thanks for the replies.
Old Mar 16, 2003 | 07:20 AM
y2kse's Avatar
Baystate Nissan is wrong . . . dead wrong. The NUMBER ONE symptom of a bad coil is pinging and loss of engine power. How do I know? Because it happened on both my 2K SE and my wife's 2K GXE. Neither of our cars threw SES lights. And Nissan replaced all 6 coils in both of our cars under warranty.
If you have a coil problem . . . and that's exactly what it sounds like you have . . . replacing your spark plugs won't stop the pinging or restore your power. I'd suggest you follow 2kSeattleMax's advice instead.
Old Mar 16, 2003 | 07:35 AM
Maximam's Avatar
Old Mar 16, 2003 | 08:20 AM
What is the TSB for the coils? I used to have it, but i lost it. Thanks guys for all your help
Old Mar 16, 2003 | 10:14 AM
y2kse's Avatar
I'm not in front of my computer. Otherwise I'd give you the TSB number. But it should still be in the TSB sticky post at the top of this forum.
Old Mar 16, 2003 | 10:21 AM
max...to the ma's Avatar
check the NHSTA
Old Mar 16, 2003 | 10:24 AM
Maximam's Avatar
http://forums.maxima.org/showthread....5&pagenumber=2
http://u1.lvcm.com/adman/MaximaOrg/T...01-059__1_.jpg
http://u1.lvcm.com/adman/MaximaOrg/T...01-059__2_.jpg
Credit: ADMAN
Old Mar 16, 2003 | 02:31 PM
scmaxima2k's Avatar
I brought mine in last thursday to the dealership for the same problem and told them i had pinging and loss of power and he said definately the coils. He then told me it was covered under the 3/36 warranty which is over for me and that they cannot replace them until the SES comes on. Im ****ed because they want 330 for the coils alone without the labor so im gonna be forced to buy the coils and do em myself.....good luck pat, lemme know how u make out so i can fix mine when i come home from skool....
-Steve
Old Mar 16, 2003 | 02:41 PM
Maximam's Avatar
No.... unless he is auto.
Old Mar 16, 2003 | 02:45 PM
TimW's Avatar
The silent but deadly Moderator
Not true, they just have to hear pinging or go by what you tell them (that you hear pinging and you are using prem gas). Read the TSB, tell them to read it as well.. Its one of the few (if not the only) TSBs that they can go on your word alone.
Old Mar 16, 2003 | 04:00 PM
scmaxima2k's Avatar
very interesting. I mentioned that i knew there was a TSB out for this problem. I remember him telling me that they have had a ton of maximas in for the ignition coil problem and maybe that could be the reason why he needs to pull the code to replace them since they are doing so many?? I dunno but im still pretty mad about it because i gotta drop $330 when there should be a recall on this in my opinion..... O well, next time i go(which wont be for a month since im back at school) ill bring a printed out copy of the TSB and see what happens but i still wont be covered under warranty or will i? Thanks Tim.
-Steve
Old Mar 16, 2003 | 10:03 PM
I had to fight so long and hard to get this done BEFORE the TSB was released.
I finally was fortunate enough to stumble across an mechanic who could replicate the problem. What he had me do was drive up a huge hill...while trying to maintain a constant rpm at about 2500. Once the engine is under a load....the ping and hesitation becomes noticeable and easy to replicate.
Not sure where you live (Texas...no hills LOL!), but if you can find a big enough incline you can replicate the problem for them.
TSB in hand is like ammo!
Old Mar 17, 2003 | 07:32 AM
y2kse's Avatar
Agreed. In my case, I was never able to get my engine to detonate in front of a service tech. I just kept bringing the car in over and over and over again. Finally, I threatened to replace all of the coils at my own expense. At that point, my Service Writer told me to hold on. He then called NNA and pleaded my case. The net result is that Nissan replaced all of my coils under warranty.
It ain't what you know . . . it's who you know that counts.
Old Mar 17, 2003 | 07:42 AM
TimW's Avatar
DaveB gave me a good tip, find an onramp with a retaining wall on either side. Its the best place to hear/replicate the pinging.
Old Mar 17, 2003 | 10:25 AM
itdood's Avatar
Pinging is a major HP robber.
If the knock sensor sends a knock count to the ECU that exceeds a threshold value, the ECU will start retarding timing until the knock counts come down to an acceptable range. I think for most cars that's about a reading of 6-10 HZ or so from the knock sensor (6-10 pings per second). Anything above that though, the ECU yanks timing which will horribly affect HP. I think some ECUs may even try to richen up the mixture way above stoich, which robs even more power.
The ECU is pulling timing to try and save the motor, as you prolly already know, pinging is very harsh on the pistons. If pre-ignition (i.e. detonation) is bad enough, just one occurance can take out a ring-land or melt a hole in the top of the piston. It's in your best interest not to let a condtion like this carry on for too long. You might want to add that to your arsenal when you talk to the service manager, maybe letting them know that you have concerns that this will lead to a major premature failure in the motor may motivate them and/or nissan to take action now before it's too late. You may need to replicate the problem with them though and there is some great advice in this thread on how to do that.
Old Mar 17, 2003 | 04:28 PM
scmaxima2k's Avatar
well thats nice hearing that my motor could be damaged because of this crap. Ive had the problem for a while now and nissan doesnt seem to want any part of helping me out. I talked to the head service manager twice about this problem alone, not to mention the numerous visits about the transmission, and they dont seem to care. Seriously if this has the potential to damage the motor why the f*ck doesnt nissan recall this sh|t. Didnt audi/VW have this same problem with some of their cars and they had a recall on all the affected cars. Why the F*CK cant nissan do this too. Unbelievable....I hope my motor is fuct up because im seriously sick of all the problems with this car. If the resale on these cars wasnt so bad id unload this thing so fast.....If they dont wanna help me next time i stop in im seriously thinking about going to a BMW, im sick of this sh|tty service.....I dunno...i love my nissan alot and im probably just talkin out of my a$$ when i say i wanna sell my baby....but this is rediculous.
-Steve
Old Mar 17, 2003 | 04:45 PM
y2kse's Avatar
Detonation is an unacceptable condition, scmaxima2k. You MUST continue to pursue this even if it means having to replace the coils yourself.
Old Mar 17, 2003 | 07:44 PM
itdood's Avatar
-Steve
I wouldn't throw the baby out with the bath water, so to speak. The ECU is doing its job in keeping conditions as safe as possible. But you really should tell the service manager that you are absolutely sure the motor is detonating, and ask for it to be documented to cover your butt (so if anything does go wrong related to it in the future you can fall back on the documentation), since they aren't taking your concerns seriously. I think you have enough info in this thread to convince them otherwise.
Old Mar 17, 2003 | 09:38 PM
LENINGRAD's Avatar
I got the same problem with my car. Can I take the car to the dealer with the Ypipe and the intake or should i take it out?
TallTom
57
Oct 14, 2025 05:16 PM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
