Replacement spark plugs
Old Mar 18, 2003 | 08:11 AM
TENZO's Avatar
Does anyone know why our factory spark plugs are so expesive ?
Some places are $26.00 each. Are they supposed to last a long
time or made of some exotic metals ? I thought they are just
platnims by NGK. Can I use other brands like Bosch or other
lesser priced ? Thank you for any input.
Tony
Old Mar 18, 2003 | 08:15 AM
[TYPE]SS's Avatar
cuz it's "FACTORY".
you can use any brand spark plugs you want. Platinums just last longer. They're all basically the same and one is NOT better then the other.
Old Mar 18, 2003 | 09:04 AM
T-bone's Avatar
uhhh ohhhhh, I would not say that if I were you!
However, you do not need to spend $26 per plug. A lot of people here recommend NGK's for about $10/ea.
Old Mar 18, 2003 | 09:05 AM
jjs's Avatar
jjs
However, you do not need to spend $26 per plug. A lot of people here recommend NKG's for about $10/ea.
I thought we had a thread discussing this around here in the past few days.
Damn that missing search function!!!
Old Mar 18, 2003 | 09:18 AM
y2kse's Avatar
Call Dave Burnette
He's selling genuine OEM NGK Platinum Plugs for around $50.00 a set. You can reach Dave at 888-254-6060.
Old Mar 18, 2003 | 10:11 AM
RC03MAX's Avatar
Re: Replacement spark plugs
Tony
Try Courtesy Nissan www,courtesyparts.com or DaveB from the *.org.....they have much better prices !!!!!!
Old Mar 18, 2003 | 12:33 PM
SR20DEN's Avatar
VQ Wizard
The only plug available for the VQ35 is the NGK which can be had for $9 - $13 per plug. If someone quotes you $26 then you should walk away and try somewhere else. I have cheacked repeatedly for Bosch but they still aren't out yet.
Be glad you don't own an M3 and have to pay $50 per plug and $150 for a freakin oil change.
Old Mar 18, 2003 | 03:50 PM
doublea's Avatar
Hey guys, saturday I bought some NGK Premium Laser Platinum ( PFR5G-11 2647 ) I got it for 17$ Canadian each at canadian tire ( about 10$ US each ) Dont know if they fit 2k2 but one thing for shure they fir the 2k1.
Cheers
AA
Old Mar 18, 2003 | 03:54 PM
E55AMG2's Avatar
Wat
I have an 89 mercedes, and the plugs are 300 for the set like yours. There arent any aftermarket that work. The factory specifies a special heat range, and if you dont use them, the engine refuses to run properly. My oil changes run 250+. This is why I use it as a weekend car ONLY
Old Mar 19, 2003 | 01:16 AM
sleepermax's Avatar
You can always use NGK coppers, part# BKR5E-11, stock #6953. I got 'em for $1.99 each, and you can probably find them cheaper. I really like the way the car runs with these. It's a little more responsive and "torquier". Copper is a much better heat conductor than platinum (better heat flow away from plug core = better conditions for a good spark), although platinum plugs will last much longer. You'll just need to replace the plugs every 25K or so - but they are well worth it. They may just be the best "mod" for the buck!
Old Mar 19, 2003 | 05:26 AM
spta97's Avatar
Ok, why is the oil change $250+???? Do they give you a new engine with that? I must know!
Old Mar 19, 2003 | 05:30 AM
SR20DEN's Avatar
VQ Wizard
I don't have a M3, I was just using it as an example.
Since TENZO failed to include what freakin car he had I assumed it was a 2002 or 2003 Maxima. His profile says he has a 2000 Maxima, therfore my post was pointless. There are an abundance of plugs for the VQ30. The VQ35 uses an entirely different plug that has a 26mm snout.
Old Mar 19, 2003 | 06:10 AM
UMD_MaxSE's Avatar
Got Bent?
I got mine for $1.59 each
Old Mar 19, 2003 | 08:46 AM
ebmaxse's Avatar
Autolite Platinum AP3924
Old Mar 19, 2003 | 10:15 AM
E55AMG2's Avatar
Wat
This is because it really isnt just an oil change. If it was, I'd do it myself. They inspect the entire car. They usually also do a full suspension lube and inspection. I'll ask my mechanic.
Old Mar 19, 2003 | 11:29 AM
maxcosity's Avatar
they are double-tipped platinum, thats why..
Slamrod
Sep 3, 2015 07:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
