Valve Body Mod
Old Sep 12, 2000 | 04:13 PM
Ripper00
Hello fellas! I just got my 2k max a couple of weeks ago and I can't wait until the break-in periods up so I can have some fun. I've reading alot of the post concerning valve body mod. What exactly is it and what improvements to the car does it make.
Old Sep 12, 2000 | 04:35 PM
The New CLIMAX's Avatar
From Don's email ---------->Long
"Modification
The VB modification is performed outside of the vehicle. The modification is done by changing the inner workings of the Valvebody. The changes actually increase fluid line pressure and re-route fluid. Soft springs are replaced with stiffer, harder springs. All gaskets are replaced with OEM Nissan parts.
What’s it mean?
What we are changing is the speed of the shifts between 1-2 and again between 2-3. The speed and firmness of the shifts are changed. That normal sloppy slow transition you experience now is fine for a smooth quiet shift (like a luxury car should be). But if you’re like me, you want every little bit of power robbing, energy-absorbing thing out of your car. That’s exactly what the OEM ValveBody does…rob you of precious power. You are losing power with every shift you make. I’ve increased my ¼ mile times by 6 tenths just with this modification. Your shifts are faster than a 5-speed (you’ll never miss one), and, at full throttle, hard enough to skip your CD player. Normal driving will be firm not sloppy, but will not snap your head back like full throttle.
Longevity
When I did my ValveBody modification almost two years ago, it was to increase the life of my slowly dying automatic transmission. After some track time with my NOS, I slowly started to feel some of the shifting fade away. I knew at that point my transmission was in its final days. At that point I had nothing to lose with my transmission so I went inside, looked around, and did some experimenting. After 3 weeks, 100 gallons of transmission fluid and $200 in OEM gaskets I found the right combination. That was TWO years ago. I just recently (August ’99) swapped out my original transmission for the I30t VLSD (that’s another story). After the Valvebody changes I went almost two more drag-racing seasons and one autocross season. If you know who I am, then you know I’ve run this car hard. It really helps increase the longevity of your automatic. I cannot guarantee this will fix any existing transmission failures or shortcomings, but it did in my case."
Old Sep 12, 2000 | 10:52 PM
mingo's Avatar
waiting
mines undergoing the change rite now.. cna't wait can't wait.. hahah im gonna b soooooooooo greased up from it
Old Sep 13, 2000 | 02:27 PM
UMD_MaxSE's Avatar
Got Bent?
How much does it cost to get the VB recalibrated and where can you get it done? Thanks..
Old Sep 13, 2000 | 08:14 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
About $450... from Don in Texas... email in sig.
Old Sep 15, 2000 | 06:29 AM
Maximizd's Avatar
Is this any good for..
the 5 Speed, or is it only for the Auto?
Old Sep 15, 2000 | 07:07 AM
Y2KevSE's Avatar
Auto only... sorry.
Old Sep 15, 2000 | 07:14 AM
mingo's Avatar
auto only
for 5 speed. just get a better clutch and practice shifting faster..
Old Nov 9, 2000 | 10:54 PM
maximaisokay's Avatar
0-60
with vb. What is the sec? I am going to save up.
John
Old Dec 16, 2003 | 08:59 AM
DavidP's Avatar
Where is this in Texas ?
What place is this in Texas ?
Old Dec 16, 2003 | 09:55 AM
Donkey®'s Avatar
wat
I knew this didn't look right for some reason.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
tardrex
Sep 11, 2015 07:35 PM
