Synthetic tranny fluid change (auto)
Old Mar 26, 2003 | 08:39 PM
jimz02max's Avatar
I know I read something regarding this topic. My question is this. I want to do this change, what is the best way to drain all of the fluid out of the drainage hole? Should the car be angled in a certain direction? And how many times should I do it to get the best percentage of synthetic in the transmission?
Old Mar 26, 2003 | 08:49 PM
ToasterMax's Avatar
Re: Synthetic tranny fluid change (auto)
Best mehtod is to drop $20 into the org donation bin and you will find the search function.
Old Mar 26, 2003 | 08:51 PM
realtor's Avatar
You won't be able to drain all the fluid at once. You'll drain about 4 to 5 quarts at a time. Maybe it's better to take the car to a shop with the equipment to drain all the fluid.
Old Mar 26, 2003 | 08:52 PM
jimz02max's Avatar
Funny thing is I was actually thinking that earlier
Old Mar 26, 2003 | 08:53 PM
jimz02max's Avatar
Re: Re: Synthetic tranny fluid change (auto)
Do you have any idea what that will cost?
Old Mar 26, 2003 | 08:56 PM
ToasterMax's Avatar
Re: Re: Re: Synthetic tranny fluid change (auto)
Max $75-100 plus the cost of your own fluid, you may need approx 10-12 qts.
Old Mar 27, 2003 | 12:27 AM
andrew3616's Avatar
i changed the tranny fluid in my 2k max about 1 month ago. I was lucky because i had the search function. There is two hose that go into the tran, one is in one is out going. I took the outgoing hose and stuck it into a bucket of fresh amsoil atf. You take the ingoing and put that in an empty bucket. You turn on the car for about as long as need for the fresh stf to comne out. Then just add atf to the top dipstick until it is full. My write up is not the good but this is basically what i did.
Old Mar 27, 2003 | 12:46 AM
ToasterMax's Avatar
did the bucket overflow?
Old Mar 27, 2003 | 02:43 AM
andrew3616's Avatar
if it was about to overflow turn off the car and epmty the bucket
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
