A/F ration gauge install help
Hey guys i finally tapped the autometer air/fule ration gauge into my o2 sensor.
Im using the one in thje front most of a 2002 max on the exhaust manifold.
I tapped into 2 dif. wires. on both ends and they dont seem to be getting the right signal.
Does anyone know which wire its suppose to be tapped into?
ANy help would be appreciated.
Thanks guys
Thanks guys
Re: A/F ration gauge install help
Thanks guys
Thanks guys
You are supposed to get the signal from the ECU, not the o2's. Call the Autometer help line, and they will tell you which wire on the ECU to tap. I know the directions say to wire into the o2's, but they are assuming you have a 3 wire Autometer o2. Save yourself the trouble, and call Autometer.
The ECU is behind the center console. Open the passenger's door and look at the center console all the way to the front of the car. There's some black plastic trim with 2 snaps. Remove the trim and there's the ECU.
Do NOT unplug the ECU harness without disconnecting the negative battery cable first, or else you may throw a SES light.
For the 2002, here are the wire locations/colors
The MAF wire is pin #62 (White)
The TACH wire is pin #34 (White/Green stripe)
The POWER wire is pin #110 or #112 (Red/Green Stripe)
The GROUND wire should not be tapped to the ECM ground wires. Use another ground elsewhere
The HEATED O2 SENSOR 1 (Bank 1) is pin #91 (White)
The HEATED O2 SENSOR 1 (Bank 2) is pin #92 (White)
The HEATED O2 SENSOR 2 (Bank 1) is pin #88 (White)
The HEATED O2 SENSOR 2 (Bank 2) is pin #90 (White)
Here's a pinout of the ECU harness:
Originally posted by Maxman2000
Well if you guys do find out which wire it is can you please tell me to because I might be buying a A/F meter soon because I just bout a pillar pod and I need to know which wire it is too. Thanks
My original post was updated to include the O2 sensor information. There are 2 sensors with 2 banks each. If the unit only taps 1 bank, use bank 1 for each sensor. Sensor #1 is the first sensor, where Sensor #2 is the rear sensor.
wow! thanks for the help,
so what #wire am I suppose to tap into?
As for the progress for the gauge...I redid the wiring and it works....
But the gauge only works to about 3400 RPM, after that it throws that green light again all the way to the right....
dam gauge!
I should just get an etg
dam gauge!
dam gauge!
dam gauge!
97_GXE
20
Sep 17, 2015 08:12 PM
BrandonCause
Sep 14, 2015 10:41 PM
