ECU Update even if TSB doesn't apply?
I was wondering if I could get the ECU even if the service department says the TSB doesn't apply. If it is just a matter of me paying for 1/2 hours work, I will, but the real question is does the TSB being inapplicable mean the car is already up to that level or possibly unable to be updated or is it just a cost savings measure by Nissan to narrow the number of cars they need to apply this to. As long as there is no technical reason preventing me from having this update done, I want it. I imagine if I offer to pay for it they will give me few problems. What does everyone think about this?
Re: ECU Update even if TSB doesn't apply?
Re: Re: ECU Update even if TSB doesn't apply?
If it works, don't fix it . . .
What's the purpose of having your ECM flashed if you don't have a problem? And if you do have a problem and your vehicle is under warranty, why are you paying to have it flashed?
Re: If it works, don't fix it . . .
Re: Re: If it works, don't fix it . . .
I do have the problem though maybe not as often as some others do. It mainly shows up in hot weather and if I can get it fixed then I want it fixed. However, if Nissan pulls the unable to duplicate on me, which they most assuredly will, then they won't do the work under warranty. I don't want to keep wasting my time bringing it in and out until they see what I see. If paying for 1/2 hours work gets them going, then so be it.
Re: Re: Re: If it works, don't fix it . . .
Originally posted by MacAlert
Call up Nissan NA and tell them the dealer is refusing to do TSB work on your car. Nissan NA will then (atleast they did for me for another issue) call up the dealership and speak to them.
Re: Re: Re: Re: If it works, don't fix it . . .
The real question is if the dealer doesn't notice it and the ECU ID isn't listed, can the TSB still be performed? I think Nissan limited the number of applicable ECU IDs to save money, but that in and of itself doesn't necessarily mean that it still can't be performed to some benefit. I just want to know if the ECU can be updayed to this latest version regardless of what the TSB says is an applicable ECU ID.
Tsb for hesitation not done.
Well I specifically went in to have this tsb looked at and got the run around from my dealer. They stated that this only applys if my check engine light was on. I need the printout of this tsb so that I can ram it in there faces. For Auto that is. On another note I told them that I was experiencing wind noise through my sunroof. 2 hrs later all they did was replace the wind deflector for free. If anyone has a written printout for auto on this tsb please email or pm me. Thanks
Re: Tsb for hesitation not done.
http://mywebpages.comcast.net/mpillmeier/TSB/
mkaresh
03-12-2018 06:48 PM
