Accelerator Pedal Released Position Learning 2k2/2k3
Old Mar 30, 2003 | 04:32 PM
MiniRX7's Avatar
Just to let you guys know, a while back i remember somebody posting something about reseeting the drive by wire system from an AUDI site.
Many of you weren't sure if this was correct.
Well in the ESM, i found out that this is actually true..
Per the ESM for 2k2 maxima.
DESCRIPTION
An operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of acclerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure accelerator is fully relased
2. Turn ignition switch "ON" and wait at least 2 seconds.
3. Turn ignition switch "OFF" and wait at least 10 seconds.
4. TUrn ignition switch "ON" and wait at least 2 seconds.
5. Turn ignition switch "OFF" and waith at least 10 seconds.
Please post your results after you perform this procedure.
HOpe this helps
ED
Old Mar 30, 2003 | 04:44 PM
studman's Avatar
If you do it one more time, it will also help reset the throttle valve closed position too.
Accelerator released position is first time. The 2nd and 3rd times are for the throttle valve closed position.
OPERATION PROCEDURE
1. Make sure accelerator is fully released
(Accelerator Released Position is learned)
4. Turn ignition switch "ON" and wait at least 2 seconds.
5. Turn ignition switch "OFF" and wait at least 10 seconds.
6. Turn ignition switch "ON" and wait at least 2 seconds.
7. Turn ignition switch "OFF" and wait at least 10 seconds.
(Throttle Valve Closed Position is learned)
Old Mar 30, 2003 | 04:48 PM
MiniRX7's Avatar
I think you got that backwards..
Throttle Valve Closed Position Learning is
Turn ignition switch off wait at least 10 secondss
ED
Old Mar 30, 2003 | 05:25 PM
Young04's Avatar
Originally posted by studman
If you do it one more time, it will also help reset the throttle body too.
Accelerator Position is first time. The 2nd and 3rd times are for the throttle body.
OPERATION PROCEDURE
(Accelerator is learned)
(Throttle Body is learned)
what does all this do?
Old Mar 30, 2003 | 05:55 PM
MetaOrbit's Avatar
Got Projectors?
I'm hoping it means I can make my car behave the way I drive now rather than the way I broke it in.
Old Mar 30, 2003 | 06:31 PM
2M0A0X2's Avatar
yeah, i dunno wtf all of this does....can someone explain?
Old Mar 30, 2003 | 06:56 PM
MiniRX7's Avatar
It trains the ECU on the actual range of the accelerator pedal range when it is in the fully unpressed position..
Basically the ECU will learn what voltage the TPS is registering when you are idling or off the throttle.
ED
Old Mar 30, 2003 | 07:23 PM
2M0A0X2's Avatar
ED
bahahaha, english please? what's TPS?
and what advantage will doing this give me?
Old Mar 30, 2003 | 07:27 PM
MiniRX7's Avatar
Throttle position sensor.
Basically, its just an adjustment procedure if your drive by wire system doesn't seem to be functioning correctly..
ED
Old Mar 30, 2003 | 08:36 PM
RC03MAX's Avatar
Re: Accelerator Pedal Released Position Learning 2k2/2k3
DESCRIPTION
OPERATION PROCEDURE
HOpe this helps
ED
You mention in another post that you have the hesitation on your 2K3...did you try this procedure and did it do anything for the hesitation ????
Old Mar 30, 2003 | 08:44 PM
MiniRX7's Avatar
Yes, on my 2k3 there is hesitation but this will not cure hestiation problems in teh 2k-3k rpms
This is only for idle, or on and off throttle
Old Mar 30, 2003 | 08:50 PM
Maxman2000's Avatar
Purple Cows.
Old Mar 30, 2003 | 09:01 PM
limsandy's Avatar
Originally posted by Maxman2000
Purple Cows.
Black meat.
~limsandy
Old Mar 30, 2003 | 09:04 PM
Maxman2000's Avatar
lol
Old Mar 30, 2003 | 10:47 PM
NizanDrivn's Avatar
Originally posted by limsandy
Black meat.
~limsandy
Mad cows!!!....mmmmm beeeefffffeeeee.....
Old Mar 30, 2003 | 11:11 PM
MiniRX7's Avatar
what are you guys talkin bout?
LOL
Old Mar 31, 2003 | 04:26 AM
Maxman2000's Avatar
LOL
h*rny purple cows.
Old Mar 31, 2003 | 08:29 AM
Born420's Avatar
I dunno anything about purple cows.... but I met a pink elephant name Jorge once.
Old Mar 31, 2003 | 09:09 AM
Maxman2000's Avatar
I know an elephant named Dumbo
Old Mar 31, 2003 | 04:03 PM
NizanDrivn's Avatar
I chatted with a pok-a-dot goat once, following the mellow brick road, way back when...
Old Jun 28, 2003 | 09:06 PM
SR20DEN's Avatar
VQ Wizard
Bump....
For those who might want to see this post that missed it.
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
