Car pulling to right when accelerating
Old Apr 5, 2003 | 11:20 AM
Draco's Avatar
I hit a pot hole a week ago, and it blew my front right tire. I replaced the tire and rotated the tires around. So Now I have 3 tires with 21k on them one, and one brand new one with 0 miles on the car. The new tire I put on the rear.
When I give the car a good amount of gas it pulls to the right. It's not a dramatic pull, but it's noticeable. All the tires are holding their air as far as I can tell. What should I do? Will an alignment fix it? Do I need to have that front right tire rebalanced? Visually, everything looked ok in the wheel well.
help.
Old Apr 5, 2003 | 11:26 AM
NT2SHBBY
make sure the inside part of the wheel isnt bent....
sounds like alignment/balancing issue
Old Apr 5, 2003 | 02:29 PM
limsandy's Avatar
Re: Car pulling to right when accelerating
help.
Try switching the right tires to the left and vice versa. If the car pulls to the left, then you can which tire is causing the problem. If not, do alignment.
~limsandy
Old Apr 5, 2003 | 03:15 PM
PeterUbers's Avatar
help.
but it doesn't pull to the right when you get off the gas and let it coast? any vibrations at highway speeds from the wheel that hit the pothole?
Old Apr 5, 2003 | 04:03 PM
Draco's Avatar
Re: Re: Car pulling to right when accelerating
It's only really noticeable when I give it a good amount of gas. Know vibrations.. yet.
Old Apr 5, 2003 | 04:05 PM
Draco's Avatar
~limsandy
Thanks, I'll try that first.
Old Apr 5, 2003 | 04:49 PM
drsprite's Avatar
When i step down on it, my car pulls to the right, then to the left, and back to the right. I believe it has something to do with the traction control trying to grip some more or something, because of the lovely potenzas.
I know this was discussed about more in detail in a prior post. I haven't hit any major pot holes, and I have this issue as well, it doesn't seem to bother me too much. I just figure it's just the power going to the front wheels.
Old Apr 5, 2003 | 07:22 PM
jimz02max's Avatar
Get the alignment done! I had the same thing happen to me a few months ago. Another thing.......are you giving it alot of gas, if so, it might be torque steer.
Old Apr 5, 2003 | 11:22 PM
RC03MAX's Avatar
Re: Re: Re: Car pulling to right when accelerating
I ran over a pothole a few weeks ago and I found out my rim was bent on the inside. And the tire didn't even blowout or lose any air. But when I put the wheel on a high speed balancing machine it was out of wack.
I don't know if you want to switch tires from right to left. I rotated mine front to back and it helped out until I was able to get a new rim.
Old Apr 6, 2003 | 05:25 AM
E55AMG2's Avatar
Wat
sounds like a case of good ole Nissan Torquesteer.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
