New plugs = SES light?
Old Apr 5, 2003 | 01:30 PM
Maximam's Avatar
New plugs = SES light?..Got the code!!!
Put new NGK plugs in yesterday. Today the SES light turns on, any relation? There is no misfire, coil packs are on tight, runs very strong.
Any ideas?
Old Apr 5, 2003 | 01:46 PM
UMD_MaxSE's Avatar
Got Bent?
what is the code?
Old Apr 5, 2003 | 03:01 PM
foodmanry's Avatar
Da Roller Coaster!
Get a code pulled from Autozone for free and post it up on here. Then we can help you.
Old Apr 5, 2003 | 04:45 PM
Maximam's Avatar
Will do and am on my way!
Old Apr 5, 2003 | 06:16 PM
Maximam's Avatar
The code is P0138 (Circuit High Volts Bank 1 + 2)?
What is this?
Old Apr 5, 2003 | 06:26 PM
UMD_MaxSE's Avatar
Got Bent?
P0138 = rear heated O2 sensor (fed spec emissions)... indicates the sensor is not reaching full voltage... I would just reset the thing and see if it comes back... this sensor only checks for the presence of a main cat and does not control A/F ratios as long as your front sensors are still working.
Old Apr 5, 2003 | 06:38 PM
Maximam's Avatar
Thanks for the reply! I will try that and see what happends. What does the part cost?
Old Apr 5, 2003 | 06:43 PM
UMD_MaxSE's Avatar
Got Bent?
Well, it could be just a bad O2 sensor... so that might have to be replaced... oh and I misread the listing previously... the code is for cali spec emissions... it is the right O2 sensor after the pre-cat in the y-pipe... not the main cat. Either way though, it only checks for the presence of the pre-cat...
Old Apr 6, 2003 | 04:20 PM
[maxi-overdose]'s Avatar
Re: New plugs = SES light?..Got the code!!!
Any ideas?
which plug did you use?
did you gap them?
Old Apr 6, 2003 | 06:14 PM
Maximam's Avatar
Re: Re: New plugs = SES light?..Got the code!!!
did you gap them?
NGK coppers BKR5E-11 stock gap
Old Apr 6, 2003 | 06:15 PM
TimW's Avatar
The silent but deadly Moderator
did you disconnect the neg battery cable?
Old Apr 6, 2003 | 06:23 PM
Maximam's Avatar
No, should I have? by the way the code is P0138???
Old Apr 6, 2003 | 06:28 PM
TimW's Avatar
yeah.. disconnect it and see if it clears..
Old Apr 7, 2003 | 06:29 AM
raiste's Avatar
Re: Re: Re: New plugs = SES light?..Got the code!!!
Yeah, you shouldn't have to re-gap new plugs.
Old Apr 7, 2003 | 06:41 AM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: Re: Re: New plugs = SES light?..Got the code!!!
you should still double check the gap before installing them...
Old Apr 7, 2003 | 08:02 AM
Maxman2000's Avatar
Just sayin this but platinums don't require gapping.
Old Apr 7, 2003 | 08:08 AM
Colonel's Avatar
Old Fuddy Duddy
Re: Re: Re: Re: Re: New plugs = SES light?..Got the code!!!
OK....I'll bite....why dont they require gapping?
Old Apr 7, 2003 | 08:12 AM
jjs's Avatar
jjs
Re: Re: Re: Re: Re: Re: New plugs = SES light?..Got the code!!!
Good question! Maybe there is a fundamental confusion of the use of the term 'gapping'. Some may consider it only when you actually change the gap on the plug. Others may use the term to cover the use of a gapping tool to double check the gap even if no actual change is made. I fall into the latter category.
Old Apr 7, 2003 | 08:17 AM
Maximam's Avatar
The plugs are copper and they were VERY close to stock gap. I don't think any of them needed much adjustment. I assume them being copper I could have gone a little larger on the gap as well but didn't.
Old Apr 7, 2003 | 08:19 AM
saxdogg's Avatar
Yes, check even when new and EVEN when they say pre-gapped. Doesn't take much of a tap to move them around...
Couldn't hurt, right?
ARFF
Old Apr 7, 2003 | 08:26 AM
Colonel's Avatar
Old Fuddy Duddy
ARFF
I just dont understand why anybody would NOT check this? It takes less than 10 seconds to check a plug. So why risk an improper gapped plug and take the "box's" word that its correct?
I guess I am more **** retentive than most....or are most not **** retentive enough?
Old Apr 7, 2003 | 08:27 AM
jjs's Avatar
jjs
Old Apr 7, 2003 | 10:23 AM
Broncs's Avatar
I was told by an R&S service person that the only plugs that came pre-gapped where the bosch plugs. But anyhow, you should always check the gap.
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
