changing spark plugs
Old Apr 11, 2003 | 03:12 PM
fixxxer's Avatar
Being that this is my first car without sparkplug wires I have no idea where my plugs are and how to pull them.
Also, I can just put regular spark plugs in there right, I dont need anything special do I? I saw some Bosch Platinum +4 plugs that looked decent for the money, but I dont know what most maxima people are using. Any input would help.
Old Apr 11, 2003 | 03:18 PM
Maximam's Avatar
Re: changing spark plugs
I used NGK coppers. Unbolt the cover over the valve cover. You will see the coil packs. Unbolt them and pull straight up to get to the plugs. You will need long extentions to reach the plugs. Do not angle the socket at all or you will break the plug. It is a 30 min job.
Someone please post that link of the how-to for me thanks!
Old Apr 11, 2003 | 03:23 PM
Uconn411's Avatar
Does this same procedure also apply to the 3.5L VQ?
Old Apr 11, 2003 | 03:29 PM
cabernet's Avatar
Re: Re: changing spark plugs
This one?
Changing Plugs
fixxxer's Avatar
wait but wouldnt only 3 be under there? its a "V" 6 not a straight. Why would all 6 plugs be lined up under that one cover
Old Apr 11, 2003 | 05:43 PM
kramerica72's Avatar
Whatever you do, don't put Bosch plugs in a Nissan--use NGK's.
Old Apr 11, 2003 | 07:05 PM
MajesticBlueNTO's Avatar
the other 3 are by the intake manifold
Old Apr 11, 2003 | 11:56 PM
HitManSE's Avatar
You guys are a trip First of all what year is your car? If you have a 3.5 (2002-03) and you dont know much about whats under the hood then have it professionally done because the intake manifold has to be removed in order the access all of the plugs. 4 of them can be reached w/o doing this but the other two arnt going nowere until the manifold is removed. If you have the 3.0 the your gonna need an allen wrench (dont remember what size) to remove the cover on the front of the motor. Then use a 8mm or 5/16 socket to loosen all the bolts that hold down the coils (please dont lose those, they are small and a pain to find) Then unclip the coils and remove them one at a time, you'll see the plugs below them and I assume you know what to do after that. As for the rear remove the coild and you need a long extension as stated by Maximam and you'll be able to reach the plugs and I think you can figure out how to put everything back together after that.
Some here may argue with you and say the Bosch plugs are good, im not 1 of them so ill just say use the NGK double platinum plugs, you dont need copper unless your going a step or so colder for nitrous.
Btw heres a little tip, have a magnetic extension tool if you possible have access to it incase you drop something and it ends up somewere your hands cant fit. Have fun.
Old Apr 12, 2003 | 04:21 AM
mjg's Avatar
mjg
this question my seem retarded... but i guess I don't care.
If we don't have spark plugs (and I guess don't have a need for them?) then why do you "change the plugs" . Do they, or do they not have spark plugs.
Old Apr 12, 2003 | 07:14 AM
y2kse's Avatar
Yes, they have spark plugs.
Old Apr 12, 2003 | 07:43 AM
HitManSE's Avatar
Unless you are driving a car/truck with a deisel motor then you definetly have spark plugs.
Old Apr 12, 2003 | 07:44 AM
Sprint's Avatar
Re: Re: Re: changing spark plugs
Originally posted by cabernet
This one?
Changing Plugs
wow that looks like my write up
http://www.sprintmax.com/tails/sparkplug.htm
kinda hard to be original these days
Old Apr 12, 2003 | 11:49 AM
cabernet's Avatar
Re: Re: Re: Re: changing spark plugs
It's not my website so I take no credit or blame. Just a site I had bookmarked because I found it useful for changing my plugs. I'm sure between the 2 sites everyone should have no problems changing plugs.
Old Apr 12, 2003 | 04:03 PM
fixxxer's Avatar
well i changed them and cleaned the throttle body, changed oil and airfilter as well. i do feel a difference, i dont know if its 100% but its definatly better than how it felt before. (felt like i was driving with 6 people in the car all the time)
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
