Need a "how to" for a ghetto box install
Old Apr 15, 2003 | 12:33 AM
tfrost's Avatar
Need a "how to" for a ghetto air box install
Would someone post some more info and a "how to" on the ghetto air box filter setup for a 2k?
Thanks, T
Old Apr 15, 2003 | 01:10 AM
Y2KSESteve's Avatar
Directions
GAB for 2k.
Cut the top of the filter holder to the spot that holds the filter (you'll see when you look at it.) Remove the elbow that connects to the resonator underneath the stock air intake scoop. Buy some 4" clothes dryer vent tubing and connect that to the hole where the elbow attached to the stock scoop and route that tube to the bottom of the front bumper for a cold air tube. Then get a K&N panel filter for the best airflow.
Shows what it looks like completed. This shows where the cut of the air filter holder piece is. Hopefully that all makes sense. It's really not all that difficult.
Old Apr 15, 2003 | 06:18 AM
blu02's Avatar
http://forums.maxima.org/showthread.php?threadid=33563
just did it last week, and it sounds great with a better throttle response.
Old Apr 18, 2003 | 11:33 PM
Neal728's Avatar
The part of the GAB I don't quite understand is the size of the elbow on a 2k2, i have the tubing, i cut out the piece by the filter, but what size adapter do i use? someone had a great writeup and I can't find it now.
Old Apr 19, 2003 | 07:03 PM
Neal728's Avatar
How did you connect the hose to the elbow?
Old Apr 19, 2003 | 08:02 PM
asu174's Avatar
Clay Aiken has fancy genitals
You get rid of the elbow and connect it directly to the inlet. Use a 3" coupler with clamps on each end. You can get it in the plumbing dept for like $6 at Home Depot.
Old Apr 20, 2003 | 02:00 AM
Neal728's Avatar
So I need to get the 3-3 coupler and some 3 inch dryer tubing? I have seen the coupler at home depot, i got to find the tubing and i'll be all set. Any reason not to use the OEM filter with the ghetto air box setup?
Old Apr 20, 2003 | 02:05 AM
KLOOGY's Avatar
L33t BMW Drivah
Just curious, why cant you guys dish out a bit over a 100 bucks for any kind of intake, when you drive a 30k car in many cases ?..To each his own.. But I am just curious ....
Old Apr 20, 2003 | 06:13 AM
asu174's Avatar
The Arizona boys have done some extensive research and have found that the best track times are a result from the GAB. I'm hesitant to hack my airbox up, but there are guys that are getting traps 100+ mph with this mod only.
Also, add in the decreased likliehood of blown MAFs and you've got a winner.
Old Apr 20, 2003 | 07:41 AM
blu02's Avatar
from what iv'e heard about problems with other intakes, i think this is the best bang for the buck. it only costs $40-$50, and it sounds great. it may be a fluke, but my gas milage went up 40 miles on the last fillup. i dont want a blown MAF, and some people have even taken out their CAI, or frankencar and seem to enjoy this more.
granted the car will not be in any import shows anytime soon with the GAB.
Old Apr 20, 2003 | 10:26 AM
2K2_6spd's Avatar
Look at our 1/4 times, and ask yourself again.....why do they do this????
Old Apr 20, 2003 | 10:29 AM
asu174's Avatar
How much is it to replace the air filter holder?
Old Apr 20, 2003 | 10:31 AM
2K2_6spd's Avatar
I dunno, but I bet there are a few junkyards around that have one or two. The holder is the same from 2000-2003, so there are lots of them out there.
Old Apr 20, 2003 | 10:37 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I checked this a couple weeks ago....expensive...my dealer wanted $87
Old Apr 20, 2003 | 10:55 AM
asu174's Avatar
I don't think I did this right. Do I have the filter in backwards?
Old Apr 20, 2003 | 11:01 AM
asu174's Avatar
Is this right or does the filter go the way I had it in the first picture?
Old Apr 20, 2003 | 11:03 AM
2K2_6spd's Avatar
As far as I know it will only go together one way, so even you coudn't screw it up
Old Apr 20, 2003 | 11:05 AM
asu174's Avatar
Well the filter can either go on the inside or the outside. If I put it on the inside, the side that has the ribs sticking out is visible (like picture 2). If I put it on the outside, the flat portion of the filter is visible (like picture 1).
Crap. Which one is it?
Old Apr 20, 2003 | 11:14 AM
asu174's Avatar
I figured it out. I think I have the wrong size K&N filter because it doesn't touch those tabs. But the answer is that the ribbed side is out and the filter is on the inside of the holder.
Old Apr 20, 2003 | 01:21 PM
Y2KSESteve's Avatar
Mine only went back together one way as well so...
Old Apr 20, 2003 | 01:33 PM
2K2_6spd's Avatar
Yes, the filter goes on the inside of the holder, hence the name, "Filter holder".
Old Apr 20, 2003 | 01:54 PM
KLOOGY's Avatar
L33t BMW Drivah
What is the theory behind why this works, and how it is increasing your trap speeds ?
Old Apr 20, 2003 | 01:59 PM
asu174's Avatar
I don't know but it sure as hell increased noise levels. I think I can feel a difference, although I've only had the car a couple of days.
BTW- Dave, what did you run the ooglie air duct hose from? Our intakes are different than the 2K's. My 2K had the elbow joint. My 2K2 one doesn't.
Old Apr 20, 2003 | 02:09 PM
Y2KSESteve's Avatar
I think he said he used a 4" dryer venting tube, but I'm not 100% sure...
Old Apr 20, 2003 | 02:38 PM
asu174's Avatar
Yeah, but where the hell did he run it to? There's no elbow joint to remove or anything. The bottom of the air inlet is flat with nothing running into it.
Old Apr 20, 2003 | 03:02 PM
Y2KSESteve's Avatar
Old Apr 20, 2003 | 03:06 PM
Maxman2000's Avatar
It's backwords.
Old Apr 20, 2003 | 03:07 PM
Neal728's Avatar
asu that's exactly my point, on a 2K2 there's no where to run a hose from!
Old Apr 20, 2003 | 03:09 PM
Maxman2000's Avatar
I got rid of the resinator elbow last night. I don't have a close dryer pipe thingy (I thought I did) so I have to go out and buy one . But still, the intake sound different without the elbow .
P.S. The only way to take out the intake resinator is to take out the battery right??? I have an auto tranny and there's a stupid wire thiungy magigy in the way.
Old Apr 20, 2003 | 03:14 PM
Y2KSESteve's Avatar
You dont need to remove the battery to get it off. I think theres only 2 screws holding it. Andy, I think Dave cut the bottom of his off to make the OSCAI part of it...
Old Apr 20, 2003 | 03:21 PM
Maxman2000's Avatar
I took off the two screws, I tryed removing the peceies under the bumber but I was to tyred and confused, I stayed up last night till 2:30 AM trying to install the racing pipe and indiuglo door sills but no luck. For the door sills, I need to make a new wire harness .
Old Apr 20, 2003 | 03:23 PM
Y2KSESteve's Avatar
New harness for what? You've got a bunch of the same crap I do... If all else fails with the resonator just pull. You dont need it. There shouldnt be anything you need to mess with under the bumper.
Old Apr 20, 2003 | 03:25 PM
Maxman2000's Avatar
New harness for the power to the door sills.
Old Apr 20, 2003 | 03:27 PM
Y2KSESteve's Avatar
What was wrong with yours?
Old Apr 20, 2003 | 03:29 PM
Maxman2000's Avatar
The plugs are in the wrong spot.
Did you do it yourself???
Old Apr 20, 2003 | 03:30 PM
Y2KSESteve's Avatar
Yep! Only thing on my car I didnt do myself was my springs...
Old Apr 20, 2003 | 03:33 PM
Maxman2000's Avatar
You have to tell me how you did it, please.
PM me, E-Mail me anything please tell me.
Old Apr 20, 2003 | 03:37 PM
Y2KSESteve's Avatar
I'll send you pics through AIM next time I get on and you're there.
Old Apr 20, 2003 | 03:38 PM
Maxman2000's Avatar
I'm on there now.
Old Apr 20, 2003 | 04:38 PM
asu174's Avatar
I kinda figured that you would have to cut it open on a 2k2. I'm going to leave it "as is" with the GAB then. The noise levels are relatively louder now with the box cut open anyhow.
