Here's a pic of the Crutchfield dash
Old Jan 18, 2001 | 10:59 PM
punkdork's Avatar
<img src="http://www.geocities.com/joncantrell_99/images/crutchfield_dash.jpg">
Well, what do you expect for $12. The black doesn't match the dash as much as it looks like it does in this pic. But you can see it is nowhere near as nice as the OEM GXE trim. I'll be replacing mine eventually.
Old Jan 18, 2001 | 11:02 PM
RBa's Avatar
RBa
Where's the Pic????
Where is the picture? I don't see it!
Old Jan 18, 2001 | 11:04 PM
punkdork's Avatar
The part surrounding my aftermarket radio.
Old Jan 19, 2001 | 07:40 AM
El Guapo
You got an oversized radio unit w/ your GXE, didn't you?
I just got a CD deck from Crutchfield, came with the same cheezy looking insert, and a warped plastic trim ring.
Fortunately, my GXE came with a single DIN tape deck and a pocket below. All I needed was the trim ring.
Tell me, were you cringing pulling on the dash parts when you did your install? The instructions say "pull gently". GENTLY? HAH! I was afraid I was doing something wrong and would break something
I'll post a pic when I can.
Old Jan 19, 2001 | 08:54 AM
punkdork's Avatar
Actually I have an SE so I had the SE radio. Yeah you sure do have to yank those vents out don't ya. I'll be getting the same GXE assembly you have sometime soon.
Old Jan 19, 2001 | 10:33 AM
xtantmaxima's Avatar
that's the same piece that i had custom made. That trim ring that snaps in looks so bad. That's why you need to sand, lay down fiberglass and sand again. you can paint it to match then and it looks so much better, but the GXE is a better option.
Old Jan 19, 2001 | 11:22 AM
El Guapo
As promised...
Old Jan 19, 2001 | 01:30 PM
The New CLIMAX's Avatar
How much would you sell a Custom plate to match? And what is the model
number on the crutchfield kit?
Old Jan 19, 2001 | 01:51 PM
punkdork's Avatar
Re: As promised...
Originally posted by El Guapo
God that looks so much better. More expensive too
Old Jan 19, 2001 | 05:35 PM
TimW's Avatar
The silent but deadly Moderator
RBa,
what are those? bullet hole stickers on the gas flap?
Old Jan 19, 2001 | 05:54 PM
punkdork's Avatar
Re: How much would you sell a Custom plate to match? And what is the model
Item Description
Price
003NDK778 Mounting kit
$12.00
120707550 Wiring Harness
$8.00
12040NI10 Antenna Adapter
$9.00
I HIGHLY recommend getting the wiring harness and antenna adapter, otherwise you'll have no radio reception and be doing a lot of nasty splicing.
Old Jan 19, 2001 | 05:58 PM
El Guapo
Re: Re: How much would you sell a Custom plate to match? And what is the model
Indeed! The wiring harness I got matched the head unit's wiring harness. That is, I just matched colors of wires up, then soldered them together. It couldn't have been simpler!
If you buy a head unit from Crutchfield, they include all 3 items for free. Makes the install a breeze.
Old Jan 21, 2001 | 09:14 PM
mdeal's Avatar
I came accross this product and thought about how the ABS laminates could be applied, possibly, over the Crutchfield piece if you are not please with how the black plastic looks: http://www.selectproducts.com/product/abslaminates.html
The homepage is: http://www.selectproducts.com/frameindex.htm , then select "Select Products" from the left.
I've used the Crutchfield pieces in the past (not on a Max), and they don't look the best (IMO), but they do work.
Just a thought...
Old Jan 21, 2001 | 09:44 PM
punkdork's Avatar
Thanks, but as is the radio doesn't mount too well in the crutchfield dash piece either. Its a fold down and the face can only fold down part way due to the trim. I like how the gxe trim looks much better.
Old Jan 21, 2001 | 09:47 PM
mdeal's Avatar
Can you not sand or Dremel the Crutchfield piece so your unit folds down completely?
From your description, it sounds as if your unit swings downward, like a glove box.
Old Jan 21, 2001 | 09:56 PM
punkdork's Avatar
Well no matter what I do, the plastic isn't going to match its going to look half-@ssed. I could go through all the trouble and maybe get it to look good, or I could just get the stock trim and have the lazy way out.
Old Jan 21, 2001 | 11:10 PM
JdoubleOe703's Avatar
teddibear703
ok
much like El Guapo's, I contacted my maxima dealer and purchased the stock base gxe air dam stereo kit. It cost me like 40 bucks. It looks better than any other kits. I suggest you guys buy the OEM maxima stereo kit for the GXE. I had the 2000 SE CD piece which was entirely changed to the GXE one to fit my eclipse 7002 screen. hehe
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
magiconthetire
Oct 26, 2015 09:03 PM
bigfrank
Oct 1, 2015 12:51 PM
salty318
Sep 29, 2015 01:21 PM
