leaky sunroof
Old Apr 21, 2003 | 08:38 PM
kenny's Avatar
leaky sunroof
I took my 03 GLE to a carwash Sunday to get rid of the road salt from the bottom of the car. I noticed a small leak from the sunroof right above the left edge of the front passenger seat. Instead of heading straight to the dealership service, what is the next best thing to do? My car has gone through heavy rain and spray washes from a garden hose without problems, so it must be the jet spray from the car wash that caused the leak. I have another Max GLE with sunroof and had taken it to the same car wash many times without incident. So it seems like a manufacture defect. Anyone with the same problem?
Old Apr 21, 2003 | 08:51 PM
TimW's Avatar
The silent but deadly Moderator
there is a soft rubber surround around the sunroof.. I you see a gap or the rubber is pinched somewhere, it needs to be adjusted (really easy to do).. if it seems 'centered' and there are no gaps, then its fine. It will leak with pressure. In fact you can press it with enough force to see a gap, which is normal. It shouldnt leak under normal rain.. however, its designed to leak *alittle bit*. there are drains that run down the apillar. even a big leak will not flood your car, but if the drains get plugged, you will have a serious mess..
Old Apr 21, 2003 | 09:18 PM
kenny's Avatar
Thanks for the prompt reply. I will take a look at it tomorrow and hope to find a small pinch and an easy fix. I doubt if the drains are clogged, as I don't really open the sunroof that much and the car is always garaged.
Old Apr 22, 2003 | 05:29 AM
optimus1's Avatar
drain-o
I've seen a post last year about clearing the drains ... could you resolve their location?
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
