Wheel hop broke my car!!!
Old Apr 24, 2003 | 12:34 PM
SEturner's Avatar
I took car to track Tues. and posted in 1/4 mile forum about it http://forums.maxima.org/showthread....readid=209354. On final run, I got severe wheel hop(wipers turned themselves on), but had heard that best runs were with hop, so I kept my foot in it and rode out the storm.
Now my car has a quiet "thunk" when I accelerate from stop. It is not very loud and can barely be felt. Noise is coming from front left suspension area.
By the way, this run was my slowest 60' (~2.45 seconds) and slowest quarter time and trap. I also got hop slamming second on all three runs. Car is 2k2 6spd.
Old Apr 24, 2003 | 12:38 PM
Maximam's Avatar
I'm getting 2.3 60s with 0 wheel hop. I feel wheel hop is horrible for the car. Try a happy compromise between slipping the clutch and wheel spin. Wheel hop IMO is very bad for the drivetrain.
NT2SHBBY
I think that would be considered "beatin the **** outta your car"
Old Apr 24, 2003 | 12:52 PM
PCGuRu2K's Avatar
Re: Wheel hop broke my car!!!
Originally posted by SEturner
I took car to track Tues. and posted in 1/4 mile forum about it. On final run, I got severe wheel hop(wipers turned themselves on), but had heard that best runs were with hop, so I kept my foot in it and rode out the storm.
You probably broke your motor mounts at this point
Old Apr 24, 2003 | 01:07 PM
255HP_03_SE's Avatar
This would be why wheel hop is BAD.
Old Apr 24, 2003 | 01:23 PM
2k2kev's Avatar
It's chrome alright...
just curious... how could you think that a tire breaking traction would make for a better time?
Old Apr 24, 2003 | 01:40 PM
SEturner's Avatar
One of the regular posters on this site surmised that hop was better than just spinning because the car is gaining momentary traction instead of just simply spinning. He indicated his own personal bests were with hop. Also, I was racing a Mustang GT, and I just didn't want to give up!
Old Apr 24, 2003 | 02:13 PM
"momentary traction"
Old Apr 24, 2003 | 02:24 PM
2k2kev's Avatar
I understand "not wanting to give up" but spin/hop/slip/whatever is always going to decrease time. You'd have done better to let off a little until it got under control... notice that was your worst time
Old Apr 24, 2003 | 03:22 PM
2001SE's Avatar
what is exactly wheel hop
Old Apr 24, 2003 | 03:40 PM
spudmanmike's Avatar
In a FWD car, wheel hop is when the tire has a ton of grip in it (or the track sometimes), but when the car launches, alot of the weight transfers to the rear. Unfortunately it does not leave much to hold the tire on the pavement.
In my Monte, i don't have posi and i have really only hopped the tire once and it felt like the car was just going to fall apart. Wheel hop is BAD!
Old Apr 24, 2003 | 04:32 PM
Newman's Avatar
when you accelerate too hard the tires keep momentarily losing traction. they have traction then they lose it, they get some, then lose it, then get some...etc...its like the tires are hopping off the gound. this causes the car to shake and bounce.
Old Apr 24, 2003 | 05:11 PM
BLKMAX005SPD's Avatar
Re: Re: Wheel hop broke my car!!!
how would you go about fixing your motor mounts...
because when i turn my car on it sounds like my engine is lose.
something is ****ed up
my car is ****
Old Apr 24, 2003 | 05:44 PM
Re: Re: Re: Wheel hop broke my car!!!
my car is ****
Old Apr 24, 2003 | 06:25 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
my car is ****
Buy new ones from Nissan and GIVE ME YOUR OLD ONES!!!! Hehe. Just kidding. Call Dave Burnette at (888)254-6060 once you figure out which you need. Top mount ~$117, rear bottom ~$60, front ~$65, and the trans ~$73. These are old prices, so they may be different now.
Most likely it's the rear bottom mount. Put the car on stands and crawl underneath. There is a support running lengthwise(front-to-rear) and it's mounted on that closer to the firewall. Use a crowbar or BIG azz screwdriver to pry on the support and a STRONG point on the engine. If you can wiggle the engine a little, you'll be able see if the rubber center part of the mount is torn with a flashlight. If that doesn't work, have a friend throttle the engine while you watch the mount. If it bangs metal-to-metal, you need a new one.
BTW, don't throw away the old mounts, you can POLY fill them for next time or if you can be without your car for several days, you can wait for them to cure and save you some money.
Old Apr 24, 2003 | 06:28 PM
Re: Re: Re: Re: Wheel hop broke my car!!!
Thanks for the help
Old Apr 24, 2003 | 06:33 PM
IceY2K1's Avatar
Re: Re: Re: Re: Re: Wheel hop broke my car!!!
Thanks for the help
Just remember NOT to throw away the broken ones.
Old Apr 24, 2003 | 07:44 PM
PCGuRu2K's Avatar
my car is ****
Buy some polyurethane mounts made by Place Racing.. You won't regret it.. I didn;t
Old Apr 25, 2003 | 05:00 AM
2k2kev's Avatar
Re: Re: Re: Re: Re: Re: Wheel hop broke my car!!!
why not?
Old Apr 25, 2003 | 05:05 AM
Maxman2000's Avatar
Tires woarm up and stick. Nut that's suposed to be done before taking off, Isn't it???
Old Apr 25, 2003 | 05:06 AM
Maxman2000's Avatar
The sound could be a bent strut.
Old Apr 25, 2003 | 07:28 AM
2k2kev's Avatar
Right, that's from burning out BEFORE you get on the track. Once the light goes green any slip/spin/hop means the tire is breaking traction.
Short story, wheel hop is never good unless you're looking for a reason to replace a part.
Old Apr 25, 2003 | 11:32 AM
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: Wheel hop broke my car!!!
why not?
Old Apr 25, 2003 | 12:44 PM
sorcereur's Avatar
That's the stupidest thing i have ever heard. Really is.
Old Apr 25, 2003 | 12:45 PM
Maksim2000's Avatar
Could also be the front left stabilizer link (Connects the front stabilizer bar to the control arm, has two ball joins that have a tendency to go), at least that's something that broke on my car.
Old Apr 26, 2003 | 05:52 PM
vqman
about wheel hop and good times...
the first time I ever went to the track, my best ET was 14.9, and I had MAD wheel hop on that run.
it was like 70 out, and at 1000ft though....
a month later, it was 50 out, and I ran a 14.8 w/out wheelhop...
it sucks when it's doing it, feels like the whole car is going to break apart..thank God I didn't break anything.
good luck getting it fixed.
-vq
Old Apr 27, 2003 | 08:19 AM
Galo's Avatar
Maxima Pilot
Hi, Forrest I did'nt know you were for real??
"One of the regular posters on this site surmised that hop was better than just spinning because the car is gaining momentary traction instead of just simply spinning. He indicated his own personal bests were with hop."
Stupid is as stupid does....
Old Apr 27, 2003 | 09:34 AM
Larry's Avatar
Steven Kusek with Frankencar was suppose to be manufacturing poly filled motor mounts for our 2K2's that would eliminate wheel hop. I was suppose to get one of the first sets but have not heard back from him.
Old Apr 27, 2003 | 10:50 AM
Newman's Avatar
Re: Hi, Forrest I did'nt know you were for real??
just in his defense i remember reading that a few months ago. im pretty sure the guy who said it was one of our habitual drag racers (like MardiGras or Jime). it wasnt just some random kid.
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
bassmann
Aug 3, 2015 07:53 PM
