Fuel Choice?
Old Sep 13, 2000 | 03:42 PM
hard8
Dealer put 87 unleaded at delivery. Just filled up with 76 92. Ran better with the 87 (quieter, smoother). Maybe my imagination. Called various dealers. They recommend 89.
Most said it doesn't matter. What do you guys think?
Old Sep 13, 2000 | 04:10 PM
The New CLIMAX's Avatar
I only use 93 Octane, If I spent $$$ for a car I will take
car of it a few cents will not kill me, and in the long run it will benefit.
Old Sep 13, 2000 | 05:17 PM
UMD_MaxSE's Avatar
Got Bent?
You can use gasoline with pretty much any rating greater than 87. The car has a knock sensor, so if it detects premature combustion (knocking, pinging) from using a less that 91 octane, the engine will automatically retard the timing. This will reduce performance and may even reduce your fuel efficiency. It will not harm the engine in any way though. The manual reccomends 91 octane, so you can get fill up with 1/2 93 and 1/2 89.
Old Sep 13, 2000 | 05:21 PM
dvyuan
I have a 5sp SE and I noticed if I don't use 91 Octane I get value pings when I start in 1st gear on a hill. I also feel a difference in the power especially in the higher RPM's
Old Sep 13, 2000 | 07:50 PM
TimW's Avatar
The silent but deadly Moderator
I wouldnt say that it wont do any damage..
I know what putting a engine under a heavy load while the timing is retarded will do, very bad things. And detonation at the wrong time will do even worse things, like a hole in your piston. I wouldnt feel too smart if I needed my valves redone at 90K miles because I thought the manual was full of it.
That dealer can put whatever they want in it to save a buck, but dont think for a second they wont deny you warranty engine work if they can prove you were running the wrong octane.
[Edited by TimW on 09-13-2000 at 09:52 PM]
Old Sep 13, 2000 | 10:53 PM
Neo Max's Avatar
I strictly run premium as the manual requires. I first used 91 octane and later switched to 93. I did feel crisper response using the 93 but I also get slightly worse mileage (less than 1mpg diff). Note to everyone though-never use ethanol blend fuel. I read a report that tested all major brands and the LOWEST ethanol content they found was 22%. Mitsubishi reports that injectors can only tolerate 5% at the most unless they are designed for alcohol use such as those found on FFVs (flexible fuel vehicles). Hope this helps.
Old Sep 13, 2000 | 10:58 PM
MaximaZero's Avatar
Needs non-Maxima Friends
where do u all live?? i have yet to see 93 in my area. the highest i can find is 92 in norcal.
Old Sep 13, 2000 | 11:06 PM
Neo Max's Avatar
I live in Nebraska. The gas I'm talking about is AMOCO ultimate. I was informed that all of their ultimate gold level gas is 93oct nationwide even though the pumps here only say 92. Also note that octane is a minimum rating R+M/2=octane so by industry standards it must meet at least that. Also, if anyone makes good gas it's AMOCO.
Old Sep 13, 2000 | 11:34 PM
yongjun's Avatar
all i use is mobile 93 octane premium or exxon 93 octane super. only place in texas that i know of that has 92 octane is race trac. Did i mention all the bear bottle glass in the gas as well?
Old Sep 14, 2000 | 07:04 AM
Thump
Type Of Fuel
The 2K manual suggests using Premium fuel.
Old Sep 14, 2000 | 09:17 AM
PIONEER's Avatar
Younjun my car runs very heavey on Exxon Fuel. every time I use it, it makes my car run like crap, like something is holding it back. don't hear any knocking or anything like that but the shifts b/w gear is slugish like the car doesn't really wanna go. put Amoco, or Shell and it runs like a champ.. Sorry no MOBIL 1 around here..
Old Sep 14, 2000 | 09:55 AM
tb420's Avatar
altitude
up here (salt lake city) the best stuff one can usually find is 91. our low-grade stuff is 85. 4300' is the low around here (the big stinky lake), downtown is at 4500 and around town gets up to 6000 feet. (even higher in park city) i guess with thinner air, lower octane ratings are necessary. (or so i've been told) i guess that makes my car slower too, but i still managed to hit our governed 133/4 mph top end pretty hard.
Old Sep 14, 2000 | 01:23 PM
foozed's Avatar
Not sure if it has anything to do with the company itself, or the dealers near us.. but a friend of mine with a Type-R and myself always used the Exxon around here... we both switched to Sunoco 94 and realize a smoother stronger engine.
Perhaps its Exxon's quality.. but something tells us it could be this particular distributor.
We know others that have had water in the tank that use that gas station frequently..
Old Sep 14, 2000 | 06:28 PM
Zanardi_Fan
I fell for the line of B.S. the dealer gave me about "any octane is ok"... well, let me tell ya', it's not! I noticed significant valve clattering and hesitation running 87. Since I've been using strictly 93 octane... no problems!
Dealers = Liars.
Old Sep 14, 2000 | 08:08 PM
MaxRX7
Did your car come with a manual? Did you read it? They make them for a reason you know.
Old Sep 14, 2000 | 08:43 PM
hard8
The intelligence level of those responding assumed we ALL
read the manual. If you you have nothing positive to contribute, don't post.
Old Sep 14, 2000 | 08:47 PM
TimW's Avatar
hard8....
dont take it personally.. this has been a hot topic for the last few months with people tired of paying so much for the more expensive gas. People are just getting alittle testy about it. it really needs to be a FAQ.
Old Sep 14, 2000 | 08:49 PM
punkdork's Avatar
I use Texaco 93 octane. I really haven't tried anything else except Exxon 93 octane. If it says premium, I assume it wants premium and the extra 10-20cents/gallon is worth my piece of mind.
Old Sep 14, 2000 | 10:18 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Shell 92...
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
