How do you know if you have a bad MAF`
Old Apr 30, 2003 | 05:05 PM
BLKMAX005SPD's Avatar
Well my car is running like **** and its really makin me ****ed
Everytime i hit the gas it feels like its hesitating.
I left my driveway today and hit the gas...it took a while then it kicked it and i took off.
Around 3500 RMP's when i give it gas it takes F O R E V E R to get to the higher RPM's
please help
Old Apr 30, 2003 | 05:29 PM
PHATMAN5050's Avatar
You don't have a blown maf, but your maf may be damaged or in the process of becoming blown. With a blown maf, the engine doesn't go over 2000-2500rpm in first gear. I'd take your car to nissan if its still under warranty.
Old Apr 30, 2003 | 05:30 PM
****...its outa warranty...
you think it might be a fuel filter??
i dunno what to do
Old Apr 30, 2003 | 05:47 PM
MacAlert's Avatar
Check the O2 sensor and check for the CEL.
Old Apr 30, 2003 | 05:56 PM
where are those at on the car
One more thing...not to sound like an idiot..but whats the CEL
holla back
Old Apr 30, 2003 | 06:03 PM
MacAlert's Avatar
Check Engine Light
Old Apr 30, 2003 | 06:10 PM
Originally posted by MacAlert
Check Engine Light
the check engine light is off
i should just bring it to the dealer...but i don't want to get raped in the ***.
you know what i mean
over charging me
Old Apr 30, 2003 | 06:41 PM
MacAlert's Avatar
Are you still under warranty? If you are, whatever is wrong should be covered. You might want to remove your intake before you go.
Old Apr 30, 2003 | 07:34 PM
E55AMG2's Avatar
Wat
Re: How do you know if you have a bad MAF`
Blown MAF = the engine wont start.
Old Apr 30, 2003 | 07:42 PM
Not entirely true E55AMG2
The car still starts, but you are put into 'limp' mode. This means that the engine will not go above 2000-2500rpms.
Old Apr 30, 2003 | 09:04 PM
lost all my screws to my stock intake
so i am ****ed
Old Apr 30, 2003 | 10:07 PM
chinaonnitrous1's Avatar
sounds like a failing MAF sensor. Might want to contact Dave B for a replacemnt about 80-100 bucks. 2 screws remove it, and in goes the new one. Takes 10 mints tops. Then Reset ECU by unplugging battery for a few hours. As for E55AMG, the car will start with a blown/bad/failing MAF just wont run right.
Old May 1, 2003 | 03:28 AM
2002 Maxima SE's Avatar
that about explains it. Try cleaning it out before buying a new one.
Old May 1, 2003 | 06:16 AM
Yeah i will clean it first...
What should i do to clean it
Old May 1, 2003 | 10:04 AM
[maxi-overdose]'s Avatar
i dunno what to do
I doubt it is the fuel filter. 5th gen have that in the tank and according to nissan, it doesnt have to be replaced.
you can always do a pressure check on the FPR to see if it is at proper pressure.
i dunno what to do
Old May 1, 2003 | 01:15 PM
It was the MAF...it was dirty as ****
I bought some rubbing alc...and that did the problem
Thanks for all the help
peace
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
