2000 Lights
Old Jan 21, 2001 | 07:03 PM
igorsavin's Avatar
I was trying to take out the front lights from my 2000 Maxima GXE. I only saw the 2 bolts on top of the lights. But after I took those off, I couldn't take off the lights. I couldn't find any other bolts..Please help..
Does anyone have derection of how to do it...
Also, the reason I am taking them off, is that the regular light doesn't work. However, the highbeams work..Any ideas..
Igor
Old Jan 21, 2001 | 07:10 PM
irvine78's Avatar
uh....
Igor
you know what? you probably need to replace the bulb...which means you don't have to take the whole assembly out...
Old Jan 21, 2001 | 07:11 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Igor
um.. it sounds like you have a problem with the headlamp bulb, and not the assembly. check your manual on how to replace your headlamp bulb.
Old Jan 21, 2001 | 07:13 PM
MaximaZero's Avatar
d'oh. irvine beat me to it. o well, maybe since you have to replace your bulbs anyways, you might as well upgrade to piaa superwhites or some other aftermarket bulb.
Old Jan 21, 2001 | 07:23 PM
igorsavin's Avatar
Thanks guys.
I ordered 9004 XENON 100/80w from ebay for like $16. Are this good or maybe there is something different you would recomend.
Old Jan 21, 2001 | 07:43 PM
MaximaZero's Avatar
with the higher output, i reccomend you upgrade to the apc wiring harness (~$40 at autodynamic.com) to prevent your stock harness from frying. what brand are the bulbs you bid on?
Old Jan 21, 2001 | 08:59 PM
young1976's Avatar
lights, H4 not 9004 for 5th Gen
Thanks guys.
Uhm... Assuming you have a 5th Gen that's why you posted your question on this forum... The 5th Gen's use H4 bulbs not 9004s. And see the Owner's Manual on how it's replaced, it's really easy, but weird to explain.
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
