Intake sensor Question
Old May 4, 2003 | 05:30 AM
Jacawarner's Avatar
I was looking over the stick Intake placement and associated sensors on my 2000 SE and noticed that there is a small sensor in the stock Intake, there is also another sensor or wire on the outside of the intake. What are these for and what happens to them when the stock air box is replaced with a mod?(INjen, Frankencar, etc)
Also, what will happen when you use a GAB, will these sensors work, will the ECU throw a code?
Thanks in advance
Jan
Old May 4, 2003 | 08:29 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Intake sensor Question
Thanks in advance
Jan
the one in stock scoop is the air temp sensor. the one right after the filter is the maf. with either disconnected, the ecu will throw a check engine light but without the maf it wont run over 3k rpms. if you do the gab, dont touch any of the sensors.
Old May 4, 2003 | 12:52 PM
2001SE's Avatar
is there a way not to take the air temprature sensor( the one on the scoop) without the light being turned on?
Old May 4, 2003 | 02:24 PM
sloppymax's Avatar
not that im aware of. i have moved mine from my midpipe back to stock scoop and back again with no difference being felt. those without midpipes just ziptie the sensor as close to the filter as possible. the 2k2 and up have this sensor built into the maf.
Old May 4, 2003 | 10:46 PM
2001SE's Avatar
what do you mean, i have moved mine from my midpipe? where does it go on the midpipe?
Old May 5, 2003 | 12:38 AM
Y2KSESteve's Avatar
The sensor that goes into the midpipe (not maf) should send a CEL light, but wont put you in limp mode. If you're doing the GAB, you dont need to move any of the sensors.
http://images.cardomain.com/member_i...7_110_full.jpg
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
