Tire Pressure
Old May 6, 2003 | 07:47 PM
Rich96's Avatar
Tire Pressure
What do you guys run/recommend for the stock 17s?
Old May 6, 2003 | 07:49 PM
Maxman2000's Avatar
On my se with stock 17s I put in 32 psi and it's good for me.
Old May 6, 2003 | 07:56 PM
00MaxSE's Avatar
Pointy Elbows
I'm using 34 F/R.
Old May 6, 2003 | 08:08 PM
Maxman2000's Avatar
Nissan dealership puts in 42 PSI. It feel like I'm driving a ROCk (like sponge bob square pants does in one episode).
Old May 6, 2003 | 08:52 PM
RsMaxMaggie's Avatar
Engineer/Inventor/Maximanian
Tire Pressure
I run 36 psi fronts, 32 rear to offset the extra weight up front and provide more neutral turn-in. I highly recommend this for those who feel the Max grinds its fronts WAY too early!
Old May 6, 2003 | 09:16 PM
Rich96's Avatar
Does anybody know what Nissan recommends? I looked on my console, and it only has the specs for 16s.
Old May 6, 2003 | 09:18 PM
255HP_03_SE's Avatar
I run my 17s at 36psi all around...
I ran the 17s on my Intrepid at 40psi all around and the tires lasted a long, long time (50k+ miles).
Old May 6, 2003 | 11:45 PM
ChromeSE5's Avatar
Not to steal this thread...but what does nissan say about 16's? I have em at 34psi, but they look hella flat...hmmm they are toyo's
Old May 7, 2003 | 05:01 AM
bert's Avatar
I have worn the center of two sets of tires so I am backing off. I figure I drive a bit too hard and when the heat gets to them they over-pressure.
Thanks to DW for the info, boogity boogity boogity!
Old May 7, 2003 | 07:15 AM
clipse's Avatar
I run 32psi all around.
Old May 7, 2003 | 07:18 AM
saxdogg's Avatar
ARFF
Old May 7, 2003 | 06:22 PM
slowlane's Avatar
nissan recommends 29 all the way around for 16" tires. I run 33 fronts and 31 rears. It is dangerous running too high a PSI. Unless you have specific tires that are designed for that.
Don't think that high psi will save you on gas mileage if you run a lot of highway miles. A tire with 32 psi (from a cold start) will gain 4-5 psi over an hour long trek. If you run higher PSI, I would be worried about the possible hazards you can cause to yourself and other drivers.
Dont forget to check your spare tire pressure.
Old May 7, 2003 | 08:36 PM
billyman's Avatar
35 here. I read that 35 is good because it widens the treads a little to provide better wet traction. But I'm no automotive engineer.
Old May 7, 2003 | 08:44 PM
Maxman2000's Avatar
Originally posted by saxdogg
ARFF
+3
MOOO
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
