Excessive Crank Update..
Old May 9, 2003 | 04:46 AM
DARKMETH's Avatar
He all,
For those of you that responded to my original post, I took my car into the South Point Nissan Dealership in Austin Tx yesterday and after 10 hours of diagnostics they were unable to determine what's wrong with my max. The mechanic is frustrated because all diagnostics show that the vehicle is in nominal shape but they still continue to get the excessive cranking when trying to start the vehicle and there have been instances where they can't even start the vehicle. This is second day that my max will be at the shop. For those of you that responded to my original post saying that you've experienced the same problem, as soon as hear something I will post it. Wish me luck..
Has anyone had any good/bad experiences with this dealership?
Thx
Old May 9, 2003 | 05:53 AM
SR20DEN's Avatar
VQ Wizard
Explain what you mean by "Excessive Crank".
Old May 9, 2003 | 05:56 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
same problem i used to have. crank it in the morning, drive a short distance then cut it off. return to car and when you crank it feels like it is not going turn over. sometimes it took 2 or 3 times to get it to fire. most just said the car was running too rich, which is one reason im checking my plugs to see if that condition shows up or not.
Old May 9, 2003 | 06:02 AM
SR20DEN's Avatar
VQ Wizard
Oh thats easy. Injector leakdown. Turn the key once or twice to prime the fuel rail before you crank the car.
Old May 9, 2003 | 06:12 AM
sloppymax's Avatar
Oh thats easy. Injector leakdown. Turn the key once or twice to prime the fuel rail becore you crank the car.
see for some reason, i just started doing without knowing what i was doing. i thought i could hear the whine of the fuel pump but i did not know if that is what i was hearing when i turned it two clicks.
Old May 9, 2003 | 07:28 AM
SR20DEN's Avatar
VQ Wizard
Old May 9, 2003 | 08:34 AM
DARKMETH's Avatar
as of 10:00 am...
Here's the latest.. The technician that's working on my car still does not know what's causing the failure. The diagnostics computer is still saying that everything is fine but the car won't start up on a regular basis. They turn the key, the engine starts turning but no fire. They wait a while, they try it again, it still doesn't work. Then they try it again and all of the sudden it works fine, like nothing ever happened.
Now they're telling me that they had another max go into the shop with the same symptoms and that they had to replace the VTC (variable timing chaing) sensor. The service rep hinted that it appeared that there was a tsb for this and that the tech is contacting nissan in regards to see if my vehicle meets the criteria. [B]Has anyone heard of this tsb and where I might be able to look it up?
Old May 9, 2003 | 08:43 AM
DARKMETH's Avatar
VTC
Has anyone heard of a TSB involving an issue with a "vtc?"
Old May 9, 2003 | 09:37 AM
DARKMETH's Avatar
Anyone?
Old May 9, 2003 | 09:48 AM
sloppymax's Avatar
Originally posted by DARKMETH
Anyone?
use alldata.com to find the tsb if there is one. i have not heard of it but does not mean it is not out there.
Old May 9, 2003 | 09:54 AM
SR20DEN's Avatar
VQ Wizard
Anyone?
I answered your question.
Old May 9, 2003 | 12:46 PM
SPEEDY6's Avatar
Beech Man Whore Slapper
DARKMETH,
I had the same problem with my Murano and took it to the dealership and they checked the Diag. and could not find anything wrong.
Finally we figuired it out that it was my dam KEY!!!
I guess the program on that is on the chip on my key was going bad and was sometimes reading my key, so that was the reason why it was sometimes starting and not starting at all!
Hope this helps you out
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
uttadms31
Sep 30, 2015 05:24 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
