00 Maxima - 0171 error code - SES light stays on
Old May 10, 2003 | 06:18 AM
RIC4044's Avatar
00 Maxima - 0171 error code - SES light stays on. Error code says something like system lean on bank 1 What the heck does this mean. The stupid dealership is trying to stick me -- had me pay for reprogramming the ECM - light stayed off for 3 days then came back on with same code. Now they want to replace the MAF ---- But I don't think that will do the trick. Any suggestions? What's the error codes for a bad MAF? Car stalls,hesitates when u 1st crank up- after 30 seconds it runs fine. Car has 80,000 miles- out of warranty by a long shot!!!!
Old May 10, 2003 | 08:46 AM
UMD_MaxSE's Avatar
Got Bent?
The lean condition can be caused by an air intake leak, bad front O2 sensor, a fuel delivery problem, or a bad MAF. The car stalling and hesitating indicates a faulty MAF sensor. Call up Dave Burnette and order a replacement sensor (~$100 IIRC) and swap that out. Clear the codes and then see if it comes back.
Old May 10, 2003 | 09:25 AM
RIC4044's Avatar
Again, the car only hesitates, or stalls after sitting for 5 or 6 hours, the problem lasts for 30 seconds tops - then the car drives fine. Does this still sound like a MAF? If so, I'll replace it. This is for a 00 max- original MAF on it. Did they do an upgrade from the original?
Old May 10, 2003 | 11:06 AM
UMD_MaxSE's Avatar
Got Bent?
if you have no other leaks in your air intake system, then it is probably a MAF that is on the verge of failing. I don't think Nissan updated the MAF for the '00/'01 models... just the '02 models were updated.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
wingsfan24
Aug 15, 2015 07:35 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
