Front wheel bearing problems
Old May 12, 2003 | 10:20 PM
3.0HO
I am getting vibration when turning right. Brought the car to the dealer they tell me it is a wheel bearing. Does the hub usually need to be replaced to or just the bearing? They won't cover it because of my h&r springs and "over sized rims" 18's. Saying 2hrs of work as well. Let me know what I should do?
Old May 12, 2003 | 11:49 PM
Menasor's Avatar
Re: Front wheel bearing problems
I had a wheel bearing problem too. I took the hub out and took it to my class to have it pressed out. So the hub doesn't need replacement unless you have excessive runout, but then again I would thing that a bad wheel bearing problem would cause excessive runout on the hub. So I am going to say that the hub doesn't need replacement unless the hub has physical damage. The part cost me 65 at a Nissan dealer. Good luck
Old May 13, 2003 | 08:00 AM
3.0HO
Re: Re: Front wheel bearing problems
How many hours in labour did they charge you?
Old Dec 6, 2009 | 04:02 PM
Nissanx54's Avatar
did you also have to take the knuckle out along with the hub?
Old Dec 6, 2009 | 10:00 PM
Scottwax's Avatar
That's Mr. Detail to you
I'd make sure the hub is checked out at least because if there is excessive clearance you'll be replacing the bearing again along with the hub.
Old Dec 7, 2009 | 06:54 AM
rroderiques77's Avatar
Demodded and Forgotten
The knuckle will have to be removed and a new bearing pressed inside the hub (if the hub is any good). If the hub is shot, find one at a junkyard. 2 hrs of labor is plenty.
Old Dec 7, 2009 | 02:08 PM
garybizzle's Avatar
do you know a good brand for a wheel bearing replacement? or just one thats atleast OEM? i've been looking around and cant really find any that say OEM. and when it comes to the brands, i dont know any of them..dealership wants to charge me $370 to replace just one side.
Old Dec 7, 2009 | 03:28 PM
P. Samson's Avatar
Do not concern yourself with the bearing brand name. Bearings are simple and relatively cheap. The condition (there are several critical dimensions) of the hub, the outer axleshaft, the bore of the knuckle, the knowledge of the person doing the job, and do they have the proper tooling to accomplish this job, should be more of a concern to you. Most of the cost of this job will be in the labor.
Old Dec 7, 2009 | 04:21 PM
Ghost_54's Avatar
I think I paid about 85.00 for my one front bearing another 45.00 to have it pressed in and then an hours labor (approx. 100.00) and then the car required a front end alignment another 90.00 just to give you a ball park number = 320.00
(pretty sure the dealers quote is including the alignment)
Old Dec 15, 2009 | 09:36 AM
timmyg1's Avatar
Make sure you carefully disconnect the ABS wire from the engine compartment and leave the sensor in the HUB. They usually break when you take them out. I bought new Timco bearings and had them pressed in. Have not had any other problems.
Old Dec 15, 2009 | 10:40 AM
Deckdout2's Avatar
Play with my balls
I can do this for anyone that needs new bearing pressed. Might even be able to do an exchange program since I have an extra set of spindles now. PM me.
Details here.
http://forums.maxima.org/washington-...-bearings.html
Old Dec 15, 2009 | 01:37 PM
SuperStasiu's Avatar
LMAO dude you win fail of the year for bumping a 6 YEAR OLD THREAD
Old Dec 16, 2009 | 09:45 PM
homeyclaus's Avatar
Are you the same guy who tells people to use search when there's a 6 year old thread on a subject?
I mean really - either people search or ask again. Pick one.
Old Dec 18, 2009 | 08:06 PM
webjohn's Avatar
^^^^^^^ You speak nothing but truth
Old Dec 19, 2009 | 02:16 PM
beefy23b/97's Avatar
You paid $90 for an alignment !?! I got a shop here in P town that does it for $35, your getting screwed.
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
BassAddictJ
Aug 4, 2015 11:38 AM
