Removing U shaped masking on D2R HID Bulbs
Old 05-13-2003 | 11:35 PM
3.0HO
Has anyone removed the "U" shaped masking on their D2R HID bulbs (2k2/2k3 hid owners)? If so how was lighting effected? I understand more light can be put out if this is removed? If curious about how it would effect the light direction/pattern as well? Input??
Old 05-14-2003 | 12:42 AM
HIDManic's Avatar
Re: Removing U shaped masking on D2R HID Bulbs
it looks pretty close to D2S beam pattern i would imagine. it would makes sense to just buy a D2S bulb for $50 or so. The notching is different but nothing an xacto knife won't take cafe of.
Old 05-14-2003 | 06:16 AM
NT2SHBBY
curiously, has anyone actually removed their bulbs to see who made them and if they're Philips what part # is on there? I'm curious to see what bulbs they actually are
Old 05-14-2003 | 06:36 AM
00MaxSE's Avatar
Pointy Elbows
Re: Re: Removing U shaped masking on D2R HID Bulbs
How is the D2S beam pattern different from the D2R? What cars have D2S HIDs, for example?
J.
Old 05-14-2003 | 06:48 AM
PCGuRu2K's Avatar
Re: Re: Re: Removing U shaped masking on D2R HID Bulbs
J.
Cars with projector headlights have D2S bulbs...
Reflective housing use D2R
Old 05-14-2003 | 09:42 AM
3.0HO
They are 4300k phillips d2r
Old 05-14-2003 | 09:49 AM
NT2SHBBY
have u actually removed them? is there a # on there that says 81526 or something?
Old 05-17-2003 | 01:35 PM
00MaxSE's Avatar
Pointy Elbows
BUMP
Old 05-17-2003 | 01:41 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
BUMP
Maybe this will answer some questions:
http://forums.maxima.org/showthread....S&pagenumber=1
Yes, you CAN sand the "shield" off of a D2R burner and make it a D2S, however withOUT a projector housing(BMW, Porche, S2000, 350Z, etc..), there will be glare that will annoy oncoming traffic.
Old 05-17-2003 | 02:51 PM
MetaOrbit's Avatar
Got Projectors?
How do I convert A D2R bulb to an almost D2S?
How do I make a blue bulb clear?
D2R and blucoated bulbs are less bright than a clear D2S. The coating can physically be removed.
Get a 3M Auto-Pak WetorDry Automotive Sandpaper (Walmart) (it has 220, 320, 400, and 600 grit paper) and i bought 3M 1500 grit paper. 3M rubbing compound is great to remove 1500 grit scratches. Also, use masking tape to cover the base of the bulb and the end of the bulb so water and any foregin parts do not get anywhere they do not belong.
1. Sand the ceramic paint of the D2R off with 400 grit sandpaper. Be careful and dont rub too hard and dont expect to get it all off right away. Patience and a steady hand is key.
2. Then use the 600 grit to go over the areas where the ceramic paint is/was. Do not sand any place that did not have the old ceramic D2R paint.
3. Next, use the 1500 grit paper and go back over the areas again. This is the longest part. This is the part that you can repeat. Do not repeat the above steps. The paper in the above steps will just make the scratches worse. I used a very little drop of water on the sandpaper and rubbed the D2R while it was wet. This helped alot. After, the first time using the 1500 grit dry, repeat with 1500 grit wet. After you feel that you cant do anymore or that you are making it worse, then proceed to the next step
4. Use a very small amount of the Rubbing compound and spread it using a clean cotton terry cloth. Just put enough to make a thin layer over the areas where the stripe was. To remove the rubbing compound use a clean terry cloth. To remove any film and to clean it in general, use isopropyl alcohol and a sterile natural cotton swab(better to use) or a q-tip.
5. The last step, which i didnt do but others have, is to take a dremel and attach a cotton polisher. Dont turn it up much at all otherwise you might shatter the bulb. But this should help alot. I didnt do this step. My bulb looked scratched after i was done and was extremely worried. BUt when i put it into to my projector along side the my other projector which had a regular D2S, the beam pattern and brightness were the same. So even if the bulb still looks terribly scratched dont worry aobut it b/c there is NO WAY that you can get it to look like the rest of the bulb. Just stay in the areas where the ceramic paint is and you will be fine. Dont scratch up anywhere else.
As for the bases of the D2S and D2R...they are ALMOST identical except that the notches are on opposite sides. However, to fix this problem it literally took me 30 seconds to fix. I found where the notch on the D2R needed to be fit my D2S housing, and took a triangular file and filed away; 30 seconds and problem fixed. The hardest part was figuring out which size file I needed. I got a pretty small one and made a notch just big enough for the housing's notch to fit.
In total, you have to weigh how much time you want to put into this against price of new D2S bulbs.
Sourced from the Automotive Lighting FAQ: http://faq.auto.light.tripod.com/hl-hid-bulbs.htm
The Frye
09-02-2021 12:03 PM
03-12-2020 01:06 AM
meccanj98
09-17-2015 09:28 AM
Vistance
09-17-2015 06:17 AM
meccanj98
09-16-2015 07:06 PM
