Sub solutions custom box for 5th gens!!
Old May 14, 2003 | 09:52 PM
2K2_6spd's Avatar
Those of you with Bose, this is for you, or even if you don't have Bose, you can set this up. This kit will come complete with a 2 driver box, brackets, plug and play harness to interface with the factory head unit, and will be available with, or without an Amp. Check out the pictures, PM me for more info on where to get one, and pricing. www.subsolutions.com
For the Bose guys:
Ports through the back deck, includes port, and plate
No one can tell you changed anything out
Non Bose
Port through deck on non Bose
Old May 14, 2003 | 10:22 PM
AYAYAY's Avatar
Wow! This is awesome! How many watts do you have pushing it? More importantly, how does it sound?
Old May 14, 2003 | 10:23 PM
02'maxed-out's Avatar
Old May 14, 2003 | 10:48 PM
kwd2kSE's Avatar
Check your PM please.
Mike
Old May 15, 2003 | 06:10 AM
2K2_6spd's Avatar
It will handle 325 watts, and they sound great. It won't rock your neighbors dishes off the shelf, but it sounds very rich. It compares to a 10" sub in the trunk.
Old May 15, 2003 | 06:15 AM
NT2SHBBY
I'm interest in pricing for the bose setup...how does this compare to the basslink and what does the install consist of?
Old May 15, 2003 | 06:20 AM
2K2_6spd's Avatar
The install will be straight forward. The kit will come with all the nesecary brackets, and misc parts. The advantage over this, is that you will not have to run any wires to it. We will supply you a plug and play harness to interface with the Bose harness. For more info, or pricing, please call my partner, David Hill-480-510-3420, he will answer all your questions, and take orders as well.
Old May 15, 2003 | 06:24 AM
NT2SHBBY
thank you I will do that....so you say no wires to run to it? I'm guessing it uses the factory wires off the factory sub??? is the factory amp still retained?
So I don't have to rip apart my interior running wires from the Pac adapter off the HU back to the trunk?
Old May 15, 2003 | 06:28 AM
2K2_6spd's Avatar
No, you don't have to rip out your interior, and you need to add an Amp, but we have a kit with an amp, or without. Either way, the amp will get it's signal and power from the Bose wiring. The Bose harness is hanging in the trunk, and all connections will be made there.
Old May 15, 2003 | 08:13 AM
saxdogg's Avatar
Is the sub box itself anchored to the trunk floor so it won't move around? This sounds great!
ARFF
Old May 15, 2003 | 08:38 AM
Zog's Avatar
Zog
Wow. Very impressive. And a good idea, i'm sure with the simplicity of it you'll find a large amount of people interested in this. One question, for the non-bose you will have to run wires and whatnot, correct ?
Old May 15, 2003 | 09:16 AM
swallac2
I'm guessing we are looking at teh "The Low Bass Trunk Solution." It lists on their page for $400 and I'm guessing thats minus the amp. Also, isn't the factory power wire back to there a bit thin to be used in a system to push two subs at approx 100 watts a piece? I'm not trying to be a doubter here, but I would be afraid of fire if you go cranking into it. That factory wire was meant for the two little BOSE amps in the back which probably draw much less current than an amp driving two small subs.
Old May 15, 2003 | 09:53 AM
TimW's Avatar
The silent but deadly Moderator
if you are pulling off the bose sub harness, it will be post bose equalization. :/ if you are before the main amp, you'll be pre-equalization. I know the sub amp is *in* the bose sub, but its running thru the main amp for preamp equalization. seems like if this is really low bass, the equalization will pull alot of it out at higher volume, if thats that way youre running it.
Old May 15, 2003 | 10:24 AM
NT2SHBBY
english please...
Old May 15, 2003 | 03:21 PM
subdocmax's Avatar
sub box
We have a single sub box for the maxima also, it takes up less space then the box in the pic need someone in the PHX AZ area to test it in call me at 480-510-3420 or email me here or at subsolutions.com ask for David
Old May 15, 2003 | 03:30 PM
GoldMember's Avatar
Re: sub box
I'm in Phoenix, but probably won't test. Sure you could find someone though. Not sure about this idea for the price and looks of it.
Old May 15, 2003 | 04:14 PM
asu174's Avatar
Clay Aiken has fancy genitals
Re: sub box
I'm your guinea pig. See you Saturday.
Old May 16, 2003 | 06:31 AM
2K2_6spd's Avatar
Thanks for volunteering, and thank your wife for me, for letting you outta the house
Old May 17, 2003 | 02:56 PM
subdocmax's Avatar
club deals
There will be some good club deals on these subs I will get the pic of the smaller box as soon as we fit it in the car
Matt93SE
May 24, 2019 02:58 PM
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
