help with 2000 foglight bulb replacement
Old May 17, 2003 | 09:47 PM
mday840's Avatar
can anyone tell me how to replace my factory bulbs with my new h3 bulbs, i am having trouble getting the fog light case out to pull the bulb. post any info or directions please.
Old May 17, 2003 | 10:26 PM
Maxman2000's Avatar
I'd expect it to be in your drivers manual but I believe that you have to remove the splash guard on the bottom of the bumper and then do it. I don't know
Old May 17, 2003 | 10:30 PM
asu174's Avatar
Clay Aiken has fancy genitals
You will need to remove two screws and a plug on each side. Remove the Phillips head screw that goes through the bottom of the bumper. Remove the 10mm nut that holds the spashguard in in that area. Remove one plastic plug from the splash gaurd. You do NOT need to remove the big splash guard.
Once you are in that area, you will need to unplug the wiring harness. Then I forget what actually holds it in place, but something needs to be unbolted/unclipped from behind.
Check the FAQ section. There is a writeup I think.
BigDogJonx's Avatar
http://www.max-world.org/writeups/5t...oginstall.html
That shows how to do it.
Old May 18, 2003 | 02:08 AM
mday840's Avatar
thank you very much, i got them installed in about 1 hour, bigdog great pics, they helped a lot. this website is great, ill post pics of my whip when im finished and its presentable.
KristyKarina
Aug 23, 2015 09:53 AM
220k+ A32
Aug 17, 2015 03:57 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
jholley
Aug 11, 2015 09:38 AM
MikesChevelle
Aug 6, 2015 11:36 AM
