Tail light conversion
Old May 18, 2003 | 01:07 PM
NoMotive's Avatar
Im sure this has been discussed but can't search for it. I wanna put the all-red GLE tail lights onto my SE. Is the removal procedure fairly simple? Has anyone here pulled it off?
Old May 18, 2003 | 01:11 PM
Black2000maxima's Avatar
Hey u want the all reds?!!? I want the ones with the black rims!!! Wanna trade?!!? PLEEEEEEASE!!!!
Old May 18, 2003 | 01:14 PM
NoMotive's Avatar
haha i have the clears unfortunately
Old May 18, 2003 | 01:53 PM
PHATMAN5050's Avatar
I'll take em!
Old May 18, 2003 | 03:08 PM
Greg's2kGLE's Avatar
The conversion is very easy. Just pull back the trunk liner to expose the lights. Disconnect wiring harnesses. Remove the four (I think it's four) nuts, you'll need a deep socket for this. Then use a hair dryer and heat up the edges of the lights to loosen the sealant, trust me this relaly helps. Unless you are the world's strongest man, I highly suggest doing this. Then you can push from the inside and then pull from the outside and they'll come right out. You can re-use the sealant if you need too.
Old May 18, 2003 | 04:44 PM
BLaZin 2k MaX's Avatar
Re: Tail light conversion
Ill give you my all reds for your clears.
Old May 18, 2003 | 06:17 PM
billyman's Avatar
I just did mine last week. Like Greg said, 4 5/16" nuts per side and I didn't have to heat it up at all. Just park in the sunlight for a little while.
Also, I would spring for 1 roll of sealant from your local Nissan dealer ($15). It's better to error on the side of caution and avoid what might possibly turn into a trunk full of water on the next rainy day or wash day.
The process is SIMPLE. 20-30 mins maximum.
Old May 18, 2003 | 11:54 PM
NoMotive's Avatar
Re: Re: Tail light conversion
Sure... question is, how long will it take for shipping? But yes, I am down for trade... pm me your info
Old May 19, 2003 | 12:33 AM
chinaonnitrous1's Avatar
Hmm anyone know what the part number for the glue strips are?
Old May 19, 2003 | 06:11 AM
MoCoMax's Avatar
I did my tail lights a few months ago, and the idiot dealer told me I'd need 2 boxes of the stuff, and 1 was way more than enough.
PM or e-mail me with an address, and I'll mail it out to ya.
Old May 19, 2003 | 06:16 AM
MoCoMax's Avatar
I did this mod back in March, and it was a lot colder than it is now. I never even thought to use heat, but it wasn't an option, anyway - we did the swap in a mall parking lot.
I used a long breaker bar to loosen the seals - wedge one end in the trunk, and just put steady firm pressure on the back side of the light. Not enough to break any plastic pieces, but enough that the seal loosened after a minute or so. Once the seals break, they're easy to pull out.
Old May 19, 2003 | 08:18 AM
billyman's Avatar
Nissan p/n B6553-89915
Desc: Sealer
I'd take MoCoMax up on his offer & save yourself $12-$13. Again, I wouldn't trust using only the left over sealant. Saving $13 isn't worth the headache of having a trunk full of water (if Murphy decides to happen along).
Old May 23, 2003 | 09:17 PM
02VQ35's Avatar
Is the sealant from the dealer enough for 2 cars or should I get 2 boxes, i'm trading with a guy down the street and want to have enough. Chris
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Hdnseek
Sep 9, 2015 05:55 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
