waxing after clay bar
Old May 18, 2003 | 08:16 PM
MaxAtack's Avatar
There's no reason why I can't wax after I use the clay-bar, right? I wanted to make sure, just in case anyone here has done it with horrific results.
Yes, search is down for me and I keep procrastinating on my donation fee.
Old May 18, 2003 | 08:27 PM
Murf300's Avatar
Check out a site called www.detailcity.com I have gotten alot of good info from there. And yes, you can wax after claying.
Old May 18, 2003 | 08:29 PM
255HP_03_SE's Avatar
also check out http://www.zainobros.com
-R
Old May 18, 2003 | 08:32 PM
MaxAtack's Avatar
Thanks!
NizanDrivn's Avatar
I would follow the usual write up found every where...I've followed it on a friends car with no probs...
1. wash
2. Clay w/detail spray
3. rinse off or wash hastly
4. polish/wax
You MAY be able to wax after claying, but IMO I wouldn't...the clay bar leaves a residue. You could go over all the spots you clay with a clean towel and detail spray, then wax IF you aren't claying large areas....
If your claying large areas. I would just rewash quickly then wax...
A quick rewash should n't take more than 20 minutes, compared to the amount of time you'll spend going over every spot you clay to get the residue off...
Just my 2 bits...Sorry for the lenghty reply...detail-a-passionato
Old May 18, 2003 | 08:36 PM
MaxAtack's Avatar
1. wash
4. polish/wax
No no, that's good! I wasn't sure if I was suppose to let sometime pass after the clay bar or if I can go right into waxing. But I'll wash again after the clay before the wax.
Old May 18, 2003 | 09:16 PM
limsandy's Avatar
And take pictures after all the hard work so that we all can see.
~limsandy
Old May 18, 2003 | 09:23 PM
MaxAtack's Avatar
~limsandy
Sir, Aye, Aye Sir!
Old May 18, 2003 | 09:26 PM
FUEL
I am a professional detailer and here is what I do:
Hand wash the car.
Dont bother drying it because the water will add to the lubrication for claying any ways.
I use a quick detailing spray because I do not want to rewash
Spray an arear about 3 x 3 feet.
Run the clay bar back and forth until you have little to no resistance.
Take a microfiber cloth and wipe it off.
You can then either wax or polish or swirl mark remove that area or do the whole car then go over it again with a good QD and then start waxing. Re-wash is re-work and you dont need to do it if you are careful.
Old May 18, 2003 | 09:28 PM
NizanDrivn's Avatar
FYI...Autopia is also good about car detailing....loads of info there....drop in from time to time...
Old May 18, 2003 | 11:22 PM
anskyruben's Avatar
Yankees pwn you !
I did the whole clay bar on my car today. I put a coat of Meguier (sp) wax on it right after. I couldnt really tell how it ended up because it was dark when I was done. I will let you guys know tommorrow if I had any problems with doing so. I dont think so though.
gman214
Sep 25, 2015 03:03 PM
followthadollar
Sep 23, 2015 08:31 PM
Stagnet04
Sep 14, 2015 11:28 PM
