Engine Mounts for 2k2 6-speed
Old May 21, 2003 | 01:38 PM
Vadim's Avatar
Who makes them? I thought I saw someone had Frankencar ones. I am trying to minimize the wheel hop. Thanks!
Old May 21, 2003 | 01:58 PM
VMosser323's Avatar
Re: Engine Mounts for 2k2 6-speed
Bump. I want them, too.
Old May 21, 2003 | 02:37 PM
BigDogJonx's Avatar
Just go to Cattman and buy their 95-99 5spd Mounts. They are the same. I prooved it when I fit a 2k2 6spd mount that FrankenCar made for me in my 2k1 Auto.
Dixit
Old May 21, 2003 | 07:30 PM
Vadim's Avatar
any pros or cons? are they easy to install?
Dixit
Old May 21, 2003 | 08:16 PM
HitManSE's Avatar
Pros obviously are less wheel hop. Cons would probably be slightly more vibration at idle but nothing too bad im guessing. Easy to install? Well If you have done it be4 then I would say yes, if not then it might turn out to be "interesting" so to speak.
Old May 21, 2003 | 11:32 PM
Vadim's Avatar
Do you also have Place Racing ones from 4th gen? I went and checked it out, they are kind of pricey.
Old May 21, 2003 | 11:39 PM
HitManSE's Avatar
I never stated I did, but I do know enough about them to say what to expect. The stronger the mounts the more vibration you will have and less wheel hop/better launches. They are kinda pricey, but will help reduce 60ft times at the strip (considering the tires grip) which in turn will reduce the overall 1/4 mile ET. They are a bit pricey but are like stated a must with high hp cars to reduce wheelhop. The 95-99 has the same block as the 00-01 which looks like it has the same mounts as the 02-03 3.5 I personally have not tried it but am pretty sure it will work. All I know is the 6spd tends to have a bit of wheelhop upon hard lauching and the urethane mounts will definetly help.
wyobbagy
Jan 3, 2023 12:03 PM
Max139617
Oct 19, 2016 11:34 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
spidgeon
Sep 9, 2015 03:36 PM
